Performance of mmWave-Based Mesh Networks in Indoor Environments with Dynamic Blockage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Due to growing throughput demands dictated by innovative media applications (e.g., $$360^\circ $$ video streaming, augmented and virtual reality), millimeter-wave (mmWave) wireless access is considered to be a promising technology enabler for the emerging mobile networks. One of the crucial usages for such systems is indoor public protection and disaster relief (PPDR) missions, which may greatly benefit from higher mmWave bandwidths. In this paper, we assess the performance of on-demand mmWave mesh topologies in indoor environments. The evaluation was conducted by utilizing our system-level simulation framework based on a realistic floor layout under dynamic blockage conditions, 3GPP propagation model, mobile nodes, and multi-connectivity operation. Our numerical results revealed that the use of multi-connectivity capabilities in indoor deployments allows for generally improved connectivity performance whereas the associated per-node throughput growth is marginal. The latter is due to the blockage-rich environment, which is typical for indoor layouts as it distinguishes these from outdoor cases. Furthermore, the number of simultaneously supported links at each node that is required to enhance the system performance is greater than two, thus imposing considerable control overheads.
481347_1_En_11_Chapter.pdf (593.36 Ko) Télécharger le fichier
hal-02881739 , version 1 (26-06-2020)
Paternité
Rustam Pirmagomedov, Dmitri Moltchanov, Viktor Ustinov, Md Nazmus Saqib, Sergey Andreev. Performance of mmWave-Based Mesh Networks in Indoor Environments with Dynamic Blockage. 17th International Conference on Wired/Wireless Internet Communication (WWIC), Jun 2019, Bologna, Italy. pp.129-140, ⟨10.1007/978-3-030-30523-9_11⟩. ⟨hal-02881739⟩
126 Consultations
42 Téléchargements
