A Model-based Sensor Fusion Approach for Force and Shape Estimation in Soft Robotics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2020
In this paper, we address the challenge of sensor fusion in Soft Robotics for estimating forces and deformations. In the context of intrinsic sensing, we propose the use of a soft capacitive sensor to find a contact's location, and the use of pneumatic sensing to estimate the force intensity and the deformation. Using a FEM-based numerical approach, we integrate both sensing streams and model two Soft Robotics devices we have conceived. These devices are a Soft Pad and a Soft Finger. We show in an evaluation that external forces on the Soft Pad can be estimated and that the shape of the Soft Finger can be reconstructed.
PrePrint_ModelBasedSensorFusion.pdf (4.74 Mo) Télécharger le fichier
hal-02882039 , version 1 (26-06-2020)
Stefan Escaida Navarro, Björn Hein, Stefan Escaida Navarro, Steven Nagels, Hosam Alagi, et al.. A Model-based Sensor Fusion Approach for Force and Shape Estimation in Soft Robotics. IEEE Robotics and Automation Letters, 2020, 5 (4), pp.5621-5628. ⟨10.1109/LRA.2020.3008120⟩. ⟨hal-02882039⟩
1271 Consultations
861 Téléchargements
