Gamification of pure exploration for linear bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rémy Degenne
  • Fonction : Auteur
  • PersonId : 748911
  • IdHAL : remydegenne
Pierre Ménard
  • Fonction : Auteur
  • PersonId : 1022182
Xuedong Shang
Michal Valko
We investigate an active pure-exploration setting, that includes best-arm identification, in the context of linear stochastic bandits. While asymptotically optimal algorithms exist for standard multi-arm bandits, the existence of such algorithms for the best-arm identification in linear bandits has been elusive despite several attempts to address it. First, we provide a thorough comparison and new insight over different notions of optimality in the linear case, including G-optimality, transductive optimality from optimal experimental designand asymptotic optimality. Second, we design the first asymptotically optimal algorithm for fixed-confidence pure exploration in linear bandits. As a consequence, our algorithm naturally bypasses the pitfall caused by a simple but difficult instance, that most prior algorithms had to be engineered to deal with explicitly. Finally, we avoid the need to fully solve an optimal design problem by providing an approach that entails an efficient implementation.
supp.pdf (792.27 Ko) Télécharger le fichier
hal-02884330 , version 1 (29-06-2020)
  • HAL Id : hal-02884330 , version 1
Rémy Degenne, Pierre Ménard, Xuedong Shang, Michal Valko. Gamification of pure exploration for linear bandits. ICML 2020 - International Conference on Machine Learning, Aug 2020, Vienna / Virtual, Austria. ⟨hal-02884330⟩
2076 Consultations
224 Téléchargements
