Physical and biological satellite observations of the Northwest African upwelling: Spatial extent and dynamics, IEEE Trans. Geosci. Remote Sens, vol.58, issue.2, pp.1409-1421, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02355252
Surface mixing and biological activity in the North-West African upwelling, Chaos, Interdiscipl. J. Nonlinear Sci, vol.29, issue.1, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01985164
Surface mixing and biological activity in the four Eastern Boundary upwelling systems, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00998667
Surface mixing and biological activity in the North African upwelling, AGU Ocean Sci. Meetings, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01627958
Comparative study of mixing and biological activity of the Benguela and Canary upwelling systems, Geophys. Res. Lett, vol.35, issue.11, pp.1-5, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-02296657
An improved coastal upwelling index from sea surface temperature using satellite-based approach-The case of the Canary Current upwelling system, Continental Shelf Res, vol.81, pp.38-54, 2014. ,
Robust detection of the North-West African upwelling from SST images, IEEE Geosci. Remote Sens. Lett, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02565214
Application of a chlorophyll index derived from satellite data to investigate the variability of phytoplankton in the Benguela ecosystem, Afr. J. Mar. Sci, vol.29, issue.2, pp.271-282, 2007. ,
An efficient tool for automatic delimitation of Moroccan coastal upwelling using SST images, IEEE Geosci. Remote Sens. Lett, vol.12, issue.4, pp.875-879, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078655
A simple and efficient approach for coarse segmentation of Moroccan coastal upwelling, Proc. 21st Eur. Signal Process. Conf. (EUSIPCO), pp.1-5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00850445
A simple tool for automatic extraction of Moroccan coastal upwelling from sea surface temperature images, Proc. 9th ,
URL : https://hal.archives-ouvertes.fr/hal-00973756
, Int. Conf. Intell. Syst., Theories Appl. (SITA), pp.1-4, 2014.
On detectability of Moroccan coastal upwelling in sea surface temperature satellite images, Proc. Int. Symp. Vis. Comput, pp.386-395, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01078678
A simple tool for automatic extraction of the Moroccan coastal upwelling from sea surface chlorophyll images, Proc. Intell. Syst. Comput. Vis. (ISCV), pp.1-4, 2017. ,
An improved method for accurate computation of coastal upwelling index using sea surface temperature images, Proc. 9th Int. Symp. Signal, Image, Video Commun. (ISIVC), pp.76-81, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01424036
Delineation of Moroccan coastal upwelling using the principal component analysis fusion algorithm on SSC and SST images, Proc. 9th Int. Symp. Signal, Image, Video Commun. (ISIVC), pp.174-178, 2018. ,
An efficient algorithm for polynomial curve fitting, Comput. Geosci, vol.14, issue.5, pp.547-556, 1988. ,
FCM: The fuzzy C-means clustering algorithm, Comput. Geosci, vol.10, issue.2-3, pp.191-203, 1984. ,
Detection of Moroccan coastal upwelling using sea surface chlorophyll concentration, Proc. IEEE/ACS 12th Int. Conf. Comput. Syst. Appl. (AICCSA), pp.1-4, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01360038
Data fusion in 2D and 3D image processing: An overview, Proc. 10th Brazilian Symp, pp.127-134, 1997. ,
A simple fusion approach of chlorophyll images and sea surface temperature images for improving the detection of Moroccan coastal upwelling, Proc. IEEE Int. Geosci. Remote Sens. Symp. (IGARSS), pp.7208-7211, 2018. ,
Detection of Moroccan coastal upwelling using the alpha blending fusion technique of sea surface chlorophyll images and sea surface temperature images, Proc. 4th Int. Conf. Adv. Technol. Signal Image Process. (ATSIP), pp.1-5, 2018. ,
