Interference alignment and degrees of freedom of the k-user interference channel, IEEE TRANSACTIONS ON INFORMATION THEORY, vol.54, issue.8, p.3425, 2008. ,
Interference management for heterogeneous networks with spectral efficiency improvement, IEEE Wireless Communications, vol.22, issue.2, pp.101-107, 2015. ,
Blind interference alignment in two-cell z interference mimo channel, IEEE Access, vol.5, pp.10526-10532, 2017. ,
Blind interference alignment, IEEE Journal of Selected Topics in Signal Processing, vol.6, issue.3, pp.216-227, 2012. ,
Topological interference management through index coding, IEEE Transactions on Information Theory, vol.60, issue.1, pp.529-568, 2014. ,
Informed-source coding-on-demand (iscod) over broadcast channels, Proceedings. IEEE INFOCOM'98, the Conference on Computer Communications. Seventeenth Annual Joint Conference of the IEEE Computer and Communications Societies. Gateway to the 21st Century (Cat. No. 98, vol.3, pp.1257-1264, 1998. ,
Coding on demand by an informed source (iscod) for efficient broadcast of different supplemental data to caching clients, IEEE Transactions on Information Theory, vol.52, issue.6, pp.2825-2830, 2006. ,
Index coding-an interference alignment perspective, IEEE Transactions on Information Theory, vol.60, issue.9, pp.5402-5432, 2014. ,
Optimality of orthogonal access for onedimensional convex cellular networks, IEEE communications letters, vol.17, issue.9, pp.1770-1773, 2013. ,
Tdma is optimal for allunicast dof region of tim if and only if topology is chordal bipartite, IEEE Transactions on Information Theory, vol.64, issue.3, pp.2065-2076, 2018. ,
On the capacity region for index coding, 2013 IEEE International Symposium on Information Theory, pp.962-966, 2013. ,
Interference networks with no csit: Impact of topology, IEEE Transactions on Information Theory, vol.61, issue.2, pp.917-938, 2014. ,
Topological interference alignment in wireless networks ,
Topological interference management with multiple antennas, 2014 IEEE International Symposium on Information Theory, pp.1767-1771, 2014. ,
Topological interference management for hexagonal cellular networks, IEEE Transactions on Wireless Communications, vol.14, issue.5, pp.2368-2376, 2014. ,
Topological interference management with reconfigurable antennas, IEEE Transactions on Communications, vol.65, issue.11, pp.4926-4939, 2017. ,
Topological interference management with transmitter cooperation, IEEE Transactions on Information Theory, vol.61, issue.11, pp.6107-6130, 2015. ,
Topological interference management with decoded message passing, IEEE Transactions on Information Theory, vol.64, issue.5, pp.3842-3864, 2018. ,
Topological interference management with transmitter cooperation for mimo interference channels, IEEE Transactions on Vehicular Technology, vol.67, issue.11, pp.10564-10573, 2018. ,
Topological interference management with just retransmission: What are the best topologies?, 2015 IEEE International Conference on Communications (ICC), pp.4113-4119, 2015. ,
Topological interference management for mimo interference broadcast channels, IEEE Access, vol.7, pp.38055-38067, 2019. ,
Topological interference management: Trade-off between dof and sir for cellular systems, 2019 26th International Conference on Telecommunications (ICT), pp.96-101, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02364450
Topological interference management for wireless networks, IEEE Access, vol.6, pp.76942-76955, 2018. ,
