Determinantal tensor product surfaces and the method of moving quadrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions of the American Mathematical Society Année : 2021
A tensor product surface $\mathcal{S}$ is an algebraic surface that is defined as the closure of the image of a rational map $\phi$ from $\mathbb{P}^1\times \mathbb{P}^1$ to $\mathbb{P}^3$. We provide new determinantal representations of $\mathcal{S}$ under the assumptions that $\phi$ is generically injective and its base points are finitely many and locally complete intersections. These determinantal representations are matrices that are built from the coefficients of linear relations (syzygies) and quadratic relations of the bihomogeneous polynomials defining $\phi$. Our approach relies on a formalization and generalization of the method of moving quadrics introduced and studied by David Cox and his co-authors.
hal-02885789 , version 1 (01-07-2020)
Laurent Busé, Falai Chen. Determinantal tensor product surfaces and the method of moving quadrics. Transactions of the American Mathematical Society, 2021, 374, pp.4931-4952. ⟨10.1090/tran/8358⟩. ⟨hal-02885789⟩
107 Consultations
0 Téléchargements
