High frequency non-invasive (HFNI) bio-sensors as a potential tool for marine monitoring and assessments. Frontiers in Marine Science, p.3, 2016. ,
Performance enchancement of parameter estimators via dynamic regressor extension and mixing, IEEE Transactions on Automatic Control, vol.62, pp.3546-3550, 2017. ,
A survey of fault diagnosis and fault-tolerant thechniques, parts I, II: Fault diagnosis with model-based and signal-based approaches, IEEE Trans. on Industrial Electronics, p.62, 2015. ,
Signal Processing and Linear Systems, 2009. ,
System Identification Theory for the User, 1999. ,
Filter Design for Signal Processing Using MATLAB and Mathematica, 2000. ,
System Identification A Frequancy Domain Approach, 2012. ,
Time-varying parameter identification algorithms: Finite and fixedtime convergence, IEEE Transactions on Automatic Control, vol.62, pp.3670-3678, 2017. ,
An adaptive sliding-mode observer for a class of uncertain nonlinear systems, International Journal of Adaptive Control and Signal Processing, vol.32, pp.3670-3678, 2018. ,
Fixed-time estimation of parameters for non-persistent excitation, European Journal of Control, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02196637
Adaptive Signal Processing, 1985. ,
