Probing RNA structure and RNA-ligand complexes with chemical probes, Methods Enzymol, vol.318, pp.3-21, 2000. ,
Accurate detection of chemical modifications in rna by mutational profiling (map) with shapemapper 2, RNA, vol.24, issue.2, pp.143-148, 2018. ,
Guidelines for SHAPE Reagent Choice and Detection Strategy for RNA Structure Probing Studies, Biochemistry (Mosc ), vol.58, pp.2655-2664, 2019. ,
Structure-mapping of the hairpin ribozyme. Magnesium-dependent folding and evidence for tertiary interactions within the ribozyme-substrate complex, J Mol Biol, vol.244, pp.52-63, 1994. ,
RNA structure inference through chemical mapping after accidental or intentional mutations, Proc Natl Acad Sci U S A, vol.114, issue.37, pp.9876-9881, 2017. ,
Rich RNA Structure Landscapes Revealed by Mutate-and-Map Analysis, PLoS Comput Biol, vol.11, p.1004473, 2015. ,
Quantitative Dimethyl Sulfate Mapping for Automated RNA Secondary Structure Inference, Biochemistry (Mosc ), vol.51, issue.36, pp.7037-7039, 2012. ,
An RNA mapping data base for curating RNA structure mapping experiments, Bioinformatics, vol.28, issue.22, pp.3006-3008, 2012. ,
Two ribosome recruitment sites direct multiple translation events within HIV1 Gag open reading frame, Nucleic Acids Res, vol.45, pp.7382-7400, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01505282
Accurate SHAPE-directed RNA structure determination, Proc Natl Acad Sci U S A, vol.106, issue.1, pp.97-102, 2009. ,
Data-directed RNA secondary structure prediction using probabilistic modeling, RNA, vol.22, issue.8, pp.1109-1119, 2016. ,
A statistical sampling algorithm for RNA secondary structure prediction, Nucleic Acids Res, vol.31, issue.24, pp.7280-7301, 2003. ,
Probing the structure of RNAs in solution, Nucleic Acids Res, vol.15, pp.9109-9128, 1987. ,
The Interplay between Molecular Flexibility and RNA Chemical Probing Reactivities Analyzed at the Nucleotide Level via an Extensive Molecular Dynamics Study, pp.108-127, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02387476
Strong correlation between SHAPE chemistry and the generalized NMR order parameter (S2) in RNA, J Am Chem Soc, vol.130, pp.12244-12245, 2008. ,
Discovering common stem-loop motifs in unaligned RNA sequences, Nucleic Acids Res, vol.29, pp.2135-2144, 2001. ,
The IRES 5'UTR of the dicistrovirus cricket paralysis virus is a type III IRES containing an essential pseudoknot structure, Nucleic Acids Res, vol.45, pp.8993-9004, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02171275
Accurate SHAPEdirected RNA secondary structure modeling, including pseudoknots, Proc Natl Acad Sci U S A, vol.110, issue.14, pp.5498-5503, 2013. ,
HIV-2 genomic RNA contains a novel type of IRES located downstream of its initiation codon, Nature structural & molecular biology, vol.12, pp.1001-1007, 2005. ,
Quantitative Understanding of SHAPE Mechanism from RNA Structure and Dynamics Analysis, The journal of physical chemistry. B, vol.122, pp.4771-4783, 2018. ,
RNA secondary structure of the feline immunodeficiency virus 5'UTR and Gag coding region, Nucleic Acids Res, vol.36, pp.4653-4666, 2008. ,
The rna shapes studio, Bioinformatics, vol.31, pp.423-425, 2015. ,
QuShape: rapid, accurate, and best-practices quantification of nucleic acid probing information, resolved by capillary electrophoresis, RNA, vol.19, pp.63-73, 2013. ,
Enzymatic approaches to probing of RNA secondary and tertiary structure, Methods Enzymol, vol.180, pp.192-212, 1989. ,
Model-Free RNA Sequence and Structure Alignment Informed by SHAPE Probing Reveals a Conserved Alternate Secondary Structure for 16S rRNA, PLoS Comput Biol, vol.11, 2015. ,
ViennaRNA Package 2.0. Algorithms for molecular biology : AMB, 6:26, 2011. ,
SHAPE directed RNA folding, Bioinformatics, vol.32, pp.145-147, 2016. ,
DSSR: An integrated software tool for dissecting the spatial structure of RNA, Nucleic Acids Res, vol.43, issue.21, 2015. ,
Improved RNA secondary structure prediction by maximizing expected pair accuracy, RNA, vol.15, issue.10, pp.1805-1813, 2009. ,
Incorporating chemical modification constraints into a dynamic programming algorithm for prediction of RNA secondary structure, Proc Natl Acad Sci U S A, vol.101, issue.19, pp.7287-92, 2004. ,
Pareto frontier based concept selection under uncertainty, with visualization, Optimization and Engineering, vol.6, issue.1, pp.85-115, 2005. ,
The equilibrium partition function and base pair binding probabilities for RNA secondary structure, Biopolymers, vol.29, issue.6-7, pp.1105-1119, 1990. ,
The mechanisms of RNA SHAPE chemistry, J Am Chem Soc, vol.134, pp.6617-6624, 2012. ,
Speciation of a group I intron into a lariat capping ribozyme, Proc. Natl. Acad. Sci. U.S.A, vol.111, issue.21, pp.7659-7664, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02633667
RNA-Puzzles Round III: 3D RNA structure prediction of five riboswitches and one ribozyme, RNA, vol.23, pp.655-672, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02171291
Molecular Dynamics Simulations Reveal an Interplay between SHAPE Reagent Binding and RNA Flexibility. The journal of physical chemistry letters, vol.9, pp.313-318, 2018. ,
Rapid chemical probing of conformation in 16 S ribosomal RNA and 30 S ribosomal subunits using primer extension, J Mol Biol, vol.187, pp.22-2836, 1986. ,
First snapshots of the hiv-1 rna structure in infected cells and in virions, Journal of Biological Chemistry, vol.279, issue.46, pp.48397-48403, 2004. ,
Scikit-learn: Machine Learning in Python, Journal of Machine Learning Research, vol.12, pp.2825-2830, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00650905
RNAstructure: Software for RNA secondary structure prediction and analysis, BMC Bioinf, vol.11, p.129, 2010. ,
RNA secondary structure modeling at consistent high accuracy using differential SHAPE, RNA, vol.20, pp.846-854, 2014. ,
A comparison of the solution structures and conformational properties of the somatic and oocyte 5S rRNAs of Xenopus laevis, Nucleic Acids Res, vol.16, pp.2295-2312, 1988. ,
Web-scale k-means clustering, Proceedings of the 19th international conference on World Wide Web (WWW'10), pp.1177-1178, 2010. ,
Interpreting Reverse Transcriptase Termination and Mutation Events for Greater Insight into the Chemical Probing of RNA, Biochemistry (Mosc ), vol.56, pp.4713-4721, 2017. ,
From knotted to nested RNA structures: a variety of computational methods for pseudoknot removal, RNA, vol.14, pp.410-416, 2008. ,
Selective 2'-hydroxyl acylation analyzed by primer extension and mutational profiling (SHAPE-MaP) for direct, versatile and accurate RNA structure analysis, Nat Protoc, vol.10, pp.1643-1669, 2015. ,
HOTAIR forms an intricate and modular secondary structure, Mol Cell, vol.58, pp.353-361, 2015. ,
Modeling RNA secondary structure folding ensembles using SHAPE mapping data, Nucleic Acids Res, vol.46, issue.1, pp.314-323, 2017. ,
Fingerprinting noncanonical and tertiary RNA structures by differential SHAPE reactivity, J Am Chem Soc, vol.134, pp.13160-13163, 2012. ,
NNDB: the nearest neighbor parameter database for predicting stability of nucleic acid secondary structure, Nucleic Acids Res, vol.38, pp.280-282, 2010. ,
RNA folding with soft constraints: Reconciliation of probing data and thermodynamic secondary structure prediction, Nucleic Acids Res, vol.40, issue.10, pp.4261-4272, 2012. ,
Selection and evolution of NTP-specific aptamers, Nucleic Acids Res, vol.32, pp.5045-5058, 2004. ,
Selective 2'-hydroxyl acylation analyzed by primer extension (SHAPE): quantitative RNA structure analysis at single nucleotide resolution, Nat Protoc, vol.1, pp.1610-1616, 2006. ,
Improved prediction of RNA secondary structure by integrating the free energy model with restraints derived from experimental probing data, Nucleic Acids Res, vol.43, issue.15, pp.7247-7259, 2015. ,
Statistical evaluation of improvement in RNA secondary structure prediction, Nucleic acids research, vol.40, p.26, 2012. ,
Estimating RNA structure chemical probing reactivities from reverse transcriptase stops and mutations, BioRxiv, vol.292532, 2018. ,
Integrating Chemical Footprinting Data into RNA Secondary Structure Prediction, PLoS One, vol.7, issue.10, p.45160, 2012. ,
Analysis of the structure of tetrahymena nuclear rnas in vivo: telomerase rna, the selfsplicing rrna intron, and u2 snrna, RNA, vol.1, issue.4, pp.363-74, 1995. ,
