The topology of multidimensional potential energy surfaces: Theory and application to peptide structure and kinetics, The Journal of chemical physics, vol.106, issue.4, pp.1495-1517, 1997. ,
In vitro recombination and terminal elongation of RNA by Q beta replicase, The EMBO journal, vol.11, issue.13, pp.5129-5135, 1992. ,
Density of states, metastable states, and saddle points: Exploring the energy landscape of an RNA molecule, ISMB, pp.88-91, 1997. ,
A statistical sampling algorithm for RNA secondary structure prediction, Nucleic acids research, vol.31, issue.24, pp.7280-7301, 2003. ,
RNA secondary structure prediction by centroids in a Boltzmann weighted ensemble, Rna, vol.11, issue.8, pp.1157-1166, 2005. ,
Noncoding RNA genes, Current Opinion in Genetics & Development, vol.9, issue.6, pp.695-699, 1999. ,
pourRNA-a time-and memory-efficient approach for the guided exploration of RNA energy landscapes, Bioinformatics, vol.36, issue.2, pp.462-469, 2019. ,
RNA folding at elementary step resolution, RNA, vol.6, issue.3, pp.325-338, 2000. ,
Barrier trees of degenerate landscapes. Zeitschrift für physikalische chemie, vol.216, p.155, 2002. ,
Boltzmann probability of RNA structural neighbors and riboswitch detection, Bioinformatics, vol.23, issue.16, pp.2054-2062, 2007. ,
Abstract shapes of RNA, Nucleic Acids Research, vol.32, issue.16, pp.4843-4851, 2004. ,
Combinatorics of rna secondary structures, Discrete Applied Mathematics, vol.88, issue.1-3, pp.207-237, 1998. ,
Local elevation: a method for improving the searching properties of molecular dynamics simulation, Journal of computer-aided molecular design, vol.8, issue.6, pp.695-708, 1994. ,
Basin Hopping Graph: a computational framework to characterize RNA folding landscapes, Bioinformatics, vol.30, issue.14, pp.2009-2017, 2014. ,
Escaping free-energy minima, Proceedings of the National Academy of Sciences, vol.99, issue.20, pp.12562-12566, 2002. ,
Finding stable local optimal RNA secondary structures, Bioinformatics, vol.27, issue.21, pp.2994-3001, 2011. ,
2D projections of RNA folding landscapes, German conference on bioinformatics, 2009. ,
ViennaRNA Package 2.0, Algorithms for Molecular Biology, vol.6, issue.1, p.26, 2011. ,
RNA folding with hard and soft constraints, Algorithms Mol. Biol, vol.11, issue.1, 2016. ,
Computing the partition function for kinetically trapped RNA secondary structures, PLoS One, vol.6, issue.1, p.16178, 2011. ,
Np-completeness of the direct energy barrier problem without pseudoknots, International Workshop on DNA-Based Computers, pp.106-115, 2009. ,
, , pp.3-31, 2008.
The equilibrium partition function and base pair binding probabilities for RNA secondary structure, Biopolymers: Original Research on Biomolecules, vol.29, issue.6-7, pp.1105-1119, 1990. ,
Efficient approximations of RNA kinetics landscape using non-redundant sampling, Bioinformatics, vol.33, issue.14, pp.283-292, 2017. ,
Efficient sampling of RNA secondary structures from the boltzmann ensemble of low-energy, Journal of mathematical biology, vol.56, issue.1-2, pp.107-127, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00548863
RNAstructure: software for RNA secondary structure prediction and analysis, BMC bioinformatics, vol.11, issue.1, p.129, 2010. ,
Approximating the set of local minima in partial RNA folding landscapes, Bioinformatics, vol.28, issue.4, pp.523-530, 2012. ,
Novel small RNA-encoding genes in the intergenic regions of Bacillus subtilis, Gene, vol.428, issue.1, pp.2-8, 2009. ,
NNDB: the nearest neighbor parameter database for predicting stability of nucleic acid secondary structure, Nucleic acids research, vol.38, pp.280-282, 2009. ,
Efficient computation of RNA folding dynamics, Journal of Physics A: Mathematical and General, vol.37, issue.17, p.4731, 2004. ,
Complete suboptimal folding of RNA and the stability of secondary structures, Biopolymers: Original Research on Biomolecules, vol.49, issue.2, pp.145-165, 1999. ,
Prediction and statistics of pseudoknots in RNA structures using exactly clustered stochastic simulations, Proc. Natl. Acad. Sci. U.S.A, vol.100, issue.26, pp.15310-15315, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00000641
Optimal computer folding of large RNA sequences using thermodynamics and auxiliary information, Nucleic Acids Res, vol.9, issue.1, pp.133-148, 1981. ,
