3d ultrasound-guided robotic steering of a flexible needle via visual servoing, Proc. of the IEEE Int. Conf. on Robotics and Automation, pp.2250-2255, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01121224
Deep reinforcement learning for the navigation of neurovascular catheters, Current Directions in Biomedical Engineering, vol.5, issue.1, pp.5-8, 2019. ,
Force control of flexible catheter robots for beating heart surgery, Proc. of the IEEE Int. Conf. on Robotics and Automation, pp.1589-1594, 2011. ,
Vision-based online learning kinematic control for soft robots using local gaussian process regression, IEEE Robotics and Automation Letters, vol.4, issue.2, pp.1194-1201, 2019. ,
Robotic manipulation planning for shaping deformable linear objects with environmental contacts, IEEE Robotics and Automation Letters, vol.5, issue.1, pp.16-23, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02303257
Catenary-based visual servoing for tethered robots, Proc. of the IEEE Int. Conf. on Robotics and Automation, pp.732-738, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01657118
Manipulating deformable linear objects: Manipulation skill for active damping of oscillations, Proc. of the IEEE Int. Conf. on Intelligent Robots and Systems, vol.2, pp.1541-1546, 2002. ,
Adaptive sliding mode control for manipulating deformable linear object with input saturation, Proc. of the IEEE Int. Conf. on Mechatronics and Automation, pp.1862-1867, 2012. ,
Automatic 3-d manipulation of soft objects by robotic arms with an adaptive deformation model, IEEE Transactions on Robotics, vol.32, issue.2, pp.429-441, 2016. ,
Three-Dimensional Deformable Object Manipulation Using Fast Online Gaussian Process Regression, IEEE Robotics and Automation Letters, vol.3, issue.2, pp.979-986, 2018. ,
A framework for manipulating deformable linear objects by coherent point drift, IEEE Robotics and Automation Letters, vol.3, issue.4, pp.3426-3433, 2018. ,
Modelfree visual control for continuum robot manipulators via orientation adaptation, 2019. ,
Fuzzy logic control of a continuum manipulator for surgical applications, Proc. of the IEEE Int. Conf. on Robotics and Biomimetics, pp.413-418, 2014. ,
Dual-arm robotic manipulation of flexible cables, Proc. of the IEEE Int. Conf. on Intelligent Robots and Systems, pp.479-484, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01734740
Manipulation of flexible rope using topological model based on sensor information, Proc. of the IEEE Int. Conf. on Intelligent Robots and Systems, pp.2638-2643, 2006. ,
Robust algorithms for recognizing shape changes of deformable linear objects in video image sequences, Proc. of the IEEE Int. Conf. on Image Processing, vol.1, pp.335-338, 2000. ,
Deformable tracking of textured curvilinear objects, Proc. of British Machine Vision Conference, pp.1-11, 2012. ,
Track deformable objects from point clouds with structure preserved registration, The International Journal of Robotics Research, pp.1-16, 2018. ,
Occlusion-robust deformable object tracking without physics simulation, Proc. of IEEE Int. Conf. on Intelligent Robots and Systems, pp.6443-6450, 2019. ,
Tracking deformable objects with point clouds, Proc of the IEEE Int. Conf. on Robotics and Automation, pp.1130-1137, 2013. ,
On calculating with b-splines, Journal of Approximation theory, vol.6, issue.1, pp.50-62, 1972. ,
Novel approach to nonlinear/non-gaussian bayesian state estimation, Proc. of the IEE Conf. F (radar and signal processing), vol.140, pp.107-113, 1993. ,
Active deformation through visual servoing of soft objects, Proc. of the IEEE Int. Conf. on Robotics and Automation, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02499488
Tuning depth cameras for best performance ,
3D is here: Point Cloud Library (PCL), Proc. of the IEEE Int. Conf. on Robotics and Automation, 2011. ,
Visp for visual servoing: a generic software platform with a wide class of robot control skills, Robotics and Automation Magazine, vol.12, issue.4, pp.40-52, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00351899
