Improving Sound Event Detection In Domestic Environments Using Sound Separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Performing sound event detection on real-world recordings often implies dealing with overlapping target sound events and non-target sounds, also referred to as interference or noise. Until now these problems were mainly tackled at the classifier level. We propose to use sound separation as a pre-processing for sound event detection. In this paper we start from a sound separation model trained on the Free Universal Sound Separation dataset and the DCASE 2020 task 4 sound event detection baseline. We explore different methods to combine separated sound sources and the original mixture within the sound event detection. Furthermore, we investigate the impact of adapting the sound separation model to the sound event detection data on both the sound separation and the sound event detection.
SSep_SED_baseline.pdf (348.73 Ko) Télécharger le fichier
hal-02891700 , version 1 (07-07-2020)
hal-02891700 , version 2 (08-07-2020)
hal-02891700 , version 3 (10-09-2020)
hal-02891700 , version 4 (24-09-2020)
  • HAL Id : hal-02891700 , version 4
Nicolas Turpault, Scott Wisdom, Hakan Erdogan, John R Hershey, Romain Serizel, et al.. Improving Sound Event Detection In Domestic Environments Using Sound Separation. DCASE Workshop 2020 - Detection and Classification of Acoustic Scenes and Events, Nov 2020, Tokyo / Virtual, Japan. ⟨hal-02891700v4⟩
786 Consultations
1345 Téléchargements
