Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
MinYS: mine your symbiont by targeted genome assembly in symbiotic communities
Abstract : Most metazoans are associated with symbionts. Characterizing the effect of a particular symbiont often requires getting access to its genome, which is usually done by sequencing the whole community. We present MinYS, a targeted assembly approach to assemble a particular genome of interest from such metagenomic data. First, taking advantage of a reference genome, a subset of the reads is assembled into a set of backbone contigs. Then, this draft assembly is completed using the whole metagenomic readset in a de novo manner. The resulting assembly is output as a genome graph, enabling different strains with potential structural variants coexisting in the sample to be distinguished. MinYS was applied to 50 pea aphid resequencing samples, with variable diversity in symbiont communities, in order to recover the genome sequence of its obligatory bacterial sym-biont, Buchnera aphidicola. It was able to return high-quality assemblies (one contig assembly in 90% of the samples), even when using increasingly distant reference genomes, and to retrieve large structural variations in the samples. Because of its targeted essence, it outperformed standard metagenomic as-semblers in terms of both time and assembly quality.
Document type :
Journal articles
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-02891885
Contributor : Claire Lemaitre Connect in order to contact the contributor
Submitted on : Tuesday, July 7, 2020 - 10:58:13 AM
Last modification on : Friday, May 20, 2022 - 9:04:58 AM
Long-term archiving on: : Friday, November 27, 2020 - 1:00:47 PM
File
Guyomar2020.PDF
Identifiers
Citation
Cervin Guyomar, Wesley Delage, Fabrice Legeai, Christophe Mougel, Jean-Christophe Simon, et al.. MinYS: mine your symbiont by targeted genome assembly in symbiotic communities. NAR Genomics and Bioinformatics, Oxford University Press, 2020, 2 (3), pp.1-11. ⟨10.1093/nargab/lqaa047⟩. ⟨hal-02891885⟩
Share
Metrics
Record views
88
Files downloads
279
