Splitting schemes for a Lagrange multiplier formulation of FSI with immersed thin-walled structure: stability and convergence analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2023
The numerical approximation of incompressible fluid-structure interaction problems with Lagrange mul-tiplier is generally based on strongly coupled schemes. This delivers unconditional stability but at the expense of solving a computationally demanding coupled system at each time-step. For the case of the coupling with immersed thin-walled solids, we introduce a class of semi-implicit coupling schemes which avoids strongly coupling without compromising stability and accuracy. A priori energy and error estimates are derived. The theoretical results are illustrated through numerical experiments in an academic benchmark.
paper_final.pdf (791.92 Ko) Télécharger le fichier
hal-02893508 , version 1 (08-07-2020)
Michele Annese, Miguel Angel Fernández, Lucia Gastaldi. Splitting schemes for a Lagrange multiplier formulation of FSI with immersed thin-walled structure: stability and convergence analysis. IMA Journal of Numerical Analysis, 2023, 43 (2), pp.881-919. ⟨10.1093/imanum/drac004⟩. ⟨hal-02893508⟩
116 Consultations
154 Téléchargements
