Ligero: Lightweight sublinear arguments without a trusted setup, ACM CCS 2017, pp.2087-2104, 2017. ,
Probabilistic checking of proofs; A new characterization of NP, 33rd FOCS, pp.2-13, 1992. ,
Short signatures without random oracles and the SDH assumption in bilinear groups, Journal of Cryptology, vol.21, issue.2, pp.149-177, 2008. ,
Sub-linear lattice-based zero-knowledge arguments for arithmetic circuits, CRYPTO 2018, Part II, vol.10992, pp.669-699, 2018. ,
SNARKs for C: Verifying program executions succinctly and in zero knowledge, CRYPTO 2013, Part II, vol.8043, pp.90-108, 2013. ,
Arya: Nearly linear-time zero-knowledge proofs for correct program execution, ASIACRYPT 2018, Part I, volume 11272 of LNCS, pp.595-626, 2018. ,
Aurora: Transparent succinct arguments for R1CS, EUROCRYPT 2019, Part I, vol.11476, pp.103-128, 2019. ,
On defining proofs of knowledge, LNCS, vol.92, pp.390-420, 1993. ,
Leveled) fully homomorphic encryption without bootstrapping, pp.309-325, 2012. ,
Knowledge-binding commitments with applications in time-stamping, LNCS, vol.4450, pp.150-165, 2007. ,
Fully homomorphic encryption from ring-LWE and security for key dependent messages, LNCS, vol.6841, pp.505-524, 2011. ,
LegoSNARK: Modular design and composition of succinct zero-knowledge proofs, ACM CCS 2019, pp.2075-2092, 2019. ,
Faster fully homomorphic encryption: Bootstrapping in less than 0.1 seconds, ASIACRYPT 2016, Part I, vol.10031, pp.3-33, 2016. ,
URL : https://hal.archives-ouvertes.fr/cea-01832762
Faster packed homomorphic operations and efficient circuit bootstrapping for TFHE, Part I, vol.10624, pp.377-408, 2017. ,
URL : https://hal.archives-ouvertes.fr/cea-01832760
Practical verified computation with streaming interactive proofs, pp.90-112, 2012. ,
Towards practical public key systems secure against chosen ciphertext attacks, CRYPTO'91, vol.576, pp.445-456, 1992. ,
FHEW: Bootstrapping homomorphic encryption in less than a second, EUROCRYPT 2015, Part I, volume 9056 of LNCS, pp.617-640, 2015. ,
A public key cryptosystem and a signature scheme based on discrete logarithms, LNCS, vol.84, pp.10-18, 1984. ,
Efficiently verifiable computation on encrypted data, ACM CCS 2014, pp.844-855, 2014. ,
On the (in)security of SNARKs in the presence of oracles, TCC 2016-B, Part I, vol.9985, pp.108-138 ,
URL : https://hal.archives-ouvertes.fr/hal-01378013
, , 2016.
Fully homomorphic encryption using ideal lattices, 41st ACM STOC, pp.169-178, 2009. ,
Non-interactive verifiable computing: Outsourcing computation to untrusted workers, CRYPTO 2010, vol.6223, pp.465-482, 2010. ,
Quadratic span programs and succinct NIZKs without PCPs, LNCS, vol.7881, pp.626-645, 2013. ,
How to run turing machines on encrypted data, CRYPTO 2013, Part II, vol.8043, pp.536-553, 2013. ,
Delegating computation: interactive proofs for muggles, 40th ACM STOC, pp.113-122, 2008. ,
The knowledge complexity of interactive proof-systems (extended abstract), 17th ACM STOC, pp.291-304, 1985. ,
On the size of pairing-based non-interactive arguments, EUROCRYPT 2016, Part II, vol.9666, pp.305-326, 2016. ,
Homomorphic encryption from learning with errors: Conceptually-simpler, asymptotically-faster, attribute-based, CRYPTO 2013, Part I, vol.8042, pp.75-92, 2013. ,
Separating succinct non-interactive arguments from all falsifiable assumptions, 43rd ACM STOC, pp.99-108, 2011. ,
A note on efficient zero-knowledge proofs and arguments (extended abstract), 24th ACM STOC, pp.723-732, 1992. ,
Constant-size commitments to polynomials and their applications, ASIACRYPT 2010, vol.6477, pp.177-194, 2010. ,
Sonic: Zero-knowledge SNARKs from linear-size universal and updatable structured reference strings, ACM CCS 2019, pp.2111-2128, 2019. ,
Public-key cryptosystems based on composite degree residuosity classes, LNCS, vol.99, pp.223-238, 1999. ,
Pinocchio: Nearly practical verifiable computation, 2013 IEEE Symposium on Security and Privacy, pp.238-252, 2013. ,
How to delegate and verify in public: Verifiable computation from attribute-based encryption, LNCS, vol.7194, pp.422-439, 2012. ,
Security arguments for digital signatures and blind signatures, Journal of Cryptology, vol.13, issue.3, pp.361-396, 2000. ,
Signatures of correct computation, LNCS, vol.7785, pp.222-242, 2013. ,
On data banks and privacy homomorphisms. Foundations of Secure Computation, pp.169-177, 1978. ,
Fully homomorphic encryption with relatively small key and ciphertext sizes, PKC 2010, vol.6056, pp.420-443, 2010. ,
Full accounting for verifiable outsourcing, ACM CCS 2017, pp.2071-2086, 2017. ,
Doubly-efficient zkSNARKs without trusted setup, 2018 IEEE Symposium on Security and Privacy, pp.926-943, 2018. ,
Libra: Succinct zero-knowledge proofs with optimal prover computation, CRYPTO 2019, Part III, vol.11694, pp.733-764, 2019. ,
Dimitrios Papadopoulos, and Charalampos Papamanthou. vSQL: Verifying arbitrary SQL queries over dynamic outsourced databases, 2017 IEEE Symposium on Security and Privacy, pp.863-880, 2017. ,
