A Millimeter-Wave Reconfigurable Intelligent Metasurface Design for Vehicular Networks Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carola Rizza
  • Fonction : Auteur
  • PersonId : 1074591
Valeria Loscrì
  • Fonction : Auteur
  • PersonId : 1084587
A reconfigurable metasurface unit-cell is investigated in order to obtain a 0 o /180 o phase shift of the incident millimeter electromagnetic wave and its reflection for automotive applications. The meta-atom is realized starting from a ground and a dielectric layer, over which a metallic pattern is deposited. A diode is added to the pattern in order to make the structure reconfigurable in terms of phase. By tuning the substrate parameters (dielectric thickness h and dielectric constant r) and with the shape and dimensions of the pattern on the top of it, the unit-cell that satisfies the requirements is found. The S 11 of the structure is shown both in modulus and phase and compared for the two configurations of the diode. Moreover, a vehicular scenario where a whole reconfigurable intelligent metastructure based on this unit cell is described. The ideal instantaneous rate is also derived.
IEEE_VTC2020Fall.pdf (2.9 Mo) Télécharger le fichier
hal-02894947 , version 1 (09-07-2020)
  • HAL Id : hal-02894947 , version 1
Carola Rizza, Valeria Loscrì, Mohammad Ojaroudi Parchin. A Millimeter-Wave Reconfigurable Intelligent Metasurface Design for Vehicular Networks Applications. 2020 IEEE Vehicular Technology Conference, Oct 2020, Victoria, Canada. ⟨hal-02894947⟩
Collections
INRIA INRIA2
166 Consultations
385 Téléchargements
