Lyapunov functions and finite time stabilization in optimal time for homogeneous linear and quasilinear hyperbolic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Henri Poincaré C, Analyse non linéaire Année : 2022
Hyperbolic systems in one dimensional space are frequently used in modeling of many physical systems. In our recent works, we introduced time independent feedbacks leading to the finite stabilization for the optimal time of homogeneous linear and quasilinear hyperbolic systems. In this work, we present Lyapunov's functions for these feedbacks and use estimates for Lyapunov's functions to rediscover the finite stabilization results.
Lyapunov-20-07-07-archive.pdf (368.85 Ko) Télécharger le fichier
hal-02895516 , version 1 (09-07-2020)
Paternité
  • HAL Id : hal-02895516 , version 1
Jean-Michel Coron, Hoai-Minh Nguyen. Lyapunov functions and finite time stabilization in optimal time for homogeneous linear and quasilinear hyperbolic systems. Annales de l'Institut Henri Poincaré C, Analyse non linéaire, 2022, 39 (5), pp.1235-1260. ⟨hal-02895516⟩
70 Consultations
42 Téléchargements
