Artificial boundary conditions for the semi-discretized one-dimensional nonlocal Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2021
A general method is proposed to build exact artificial boundary conditions for the one-dimensional nonlocal Schrödinger equation. To this end, we first consider the spatial semi-discretization of the nonlocal equation, and then develop an accurate numerical method for computing the Green's function of the semi-discrete nonlocal Schrödinger equation. These Green's functions are next used to build the exact boundary conditions corresponding to the semi-discrete model. Numerical results illustrate the accuracy of the boundary conditions. The methodology can also be applied to other nonlocal models and could be extended to higher dimensions.
nonlocalSchrodingerJPAZ.pdf (1.02 Mo) Télécharger le fichier
hal-02898080 , version 1 (13-07-2020)
Songsong Ji, Gang Pang, Xavier Antoine, Jiwei Zhang. Artificial boundary conditions for the semi-discretized one-dimensional nonlocal Schrödinger equation. Journal of Computational Physics, 2021, 444, pp.110575. ⟨10.1016/j.jcp.2021.110575⟩. ⟨hal-02898080⟩
84 Consultations
124 Téléchargements
