Dispersive and dissipative behaviour of high order discontinuous Galerkin finite element methods, Journal of Computational Physics, vol.198, pp.106-130, 2004. ,
Dispersive properties of high-order Nédélec/edge element approximation of the timeharmonic maxwell equations, Philosophical Transactions of the Royal Society of London. Series A: Mathematical, Physical and Engineering Sciences, vol.362, pp.471-491, 1816. ,
Dispersive and dissipative properties of discontinuous Galerkin finite element methods for the second-order wave equation, Journal of Scientific Computing, vol.27, issue.1-3, pp.5-40, 2006. ,
The partition of unity method, International journal for numerical methods in engineering, vol.40, issue.4, pp.727-758, 1997. ,
A symmetric DG formulation based on a local boundary element method for the solution of the Helmholtz equation, Journal of Computational Physics, vol.330, pp.1069-1092, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01395861
A fast, high-order algorithm for the solution of surface scattering problems: basic implementation, tests, and applications, Journal of Computational Physics, vol.169, issue.1, pp.80-110, 2001. ,
Error estimates for the ultra weak variational formulation of the Helmholtz equation, Mathematical Modelling and Numerical Analysis, vol.42, issue.6, pp.925-940, 2008. ,
The electromagnetic inverse-scattering problem for partly coated Lipschitz domains, Proceedings of the Royal Society of Edinburgh Section A: Mathematics, vol.134, issue.4, pp.661-682, 2004. ,
Application d'une nouvelle formulation variationnelle aux équations d'ondes harmoniques. Problèmes d'Helmholtz 2D et de Maxwell 3D, 1996. ,
Application of an ultra weak variational formulation of elliptic PDE to the two-dimensional Helmholtz problem, SIAM J. Num. Analysis, vol.35, issue.1, pp.255-299, 1998. ,
Numerical investigation of the conditioning for plane wave discontinuous galerkin methods, European Conference on Numerical Mathematics and Advanced Applications, pp.493-500, 2017. ,
The fast multipole method: numerical implementation, Journal of Computational Physics, vol.160, issue.1, pp.195-240, 2000. ,
Sur une formulation variationnelle ultra-faible. Comptes Rendus de l'Académie des Sciences, Série I, vol.318, pp.939-944, 1994. ,
, Computers & Mathematics with Applications, vol.64, issue.8, pp.2765-2774, 2012.
Discontinuous Galerkin methods with plane waves for time-harmonic problems, Journal of Computational Physics, vol.225, 1961. ,
A comparison of two Trefftz-type methods: The ultraweak variational formulation and the least-squares method, for solving shortwave 2-D Helmholtz problems, International Journal for Numerical Methods in Engineering, vol.71, pp.406-432, 2007. ,
Dispersion analysis of plane wave discontinuous methods, International Journal for Numerical Methods in Engineering, vol.98, issue.5, pp.313-323, 2014. ,
Plane wave discontinuous Galerkin methods: analysis of the h-version, Mathematical Modelling and Numerical Analysis, vol.43, pp.297-331, 2009. ,
A survey of trefftz methods for the helmholtz equation, Building bridges: connections and challenges in modern approaches to numerical partial differential equations, pp.237-279, 2016. ,
Approximation by harmonic polynomials in starshaped domains and exponential convergence of Trefftz hp-dgfem, Mathematical Modelling and Numerical Analysis, vol.48, pp.727-752, 2014. ,
A Non-standard Finite Element Method using Boundary Integral Operators, 2012. ,
Convection-adapted BEM-based FEM, ZAMM-Journal of Applied Mathematics and Mechanics/Zeitschrift für Angewandte Mathematik und Mechanik, vol.96, issue.12, pp.1467-1481, 2016. ,
Stabilized interior penalty methods for the time-harmonic Maxwell equations, Comput. Methods Appl. Mech. Engrg, vol.191, pp.4675-4697, 2002. ,
Finite element solution of the Helmholtz equation with high wave numberpart i: the h-version of the FEM, Computers Math. Applic, vol.30, issue.9, pp.9-37, 1995. ,
Finite element solution of the Helmholtz equation with high wave numberpart ii: the h-p version of the FEM, SIAM J. Numer. Anal, vol.34, issue.1, pp.315-358, 1997. ,
, The Finite Element Method in Electromagnetics, 2002.
Improvements for the ultra weak variational formulation, International Journal for Numerical Methods in Engineering, vol.94, issue.6, pp.598-624, 2013. ,
Optimal discrete transmission conditions for a non-overlapping domain decomposition method for the Helmholtz equation, SIAM Journal on Scientific Computing, vol.25, issue.5, pp.1497-1515, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00624189
Strongly Elliptic Systems and Boundary Integral Equations, 2000. ,
General DG-Methods for highly indefinite Helmholtz problems, J. Sci. Comput, vol.57, pp.536-581, 2013. ,
Plane wave approximation of homogeneous Helmholtz solutions, Z. Angew. Math. Phys, vol.62, pp.809-837, 2011. ,
Finite Element Methods for Maxwell's Equations. Numerical Analysis and Scientific Computations, 2003. ,
A least-squares method for the helmholtz equation, Computer Methods in Applied Mechanics and Engineering, vol.175, issue.1-2, pp.121-136, 1999. ,
Mixed finite elements in R 3, Numer. Math, vol.35, pp.315-341, 1980. ,
A new family of mixed finite elements in R 3, Numer. Math, vol.50, pp.57-81, 1986. ,
Hybridizable discontinuous galerkin methods for the timeharmonic maxwell's equations, Journal of Computational Physics, vol.230, issue.19, pp.7151-7175, 2011. ,
Iterative Methods for Sparse Linear Systems, PWS Pblishing Company, 1996. ,
, Boundary Element Methods, 2011.
, Approximate Boundary Conditions in Electromagnetics. IEE Electromagnetic Waves Series 41, 1995.
Hybrid-Trefftz six-node triangular finite element models for Helmholtz problems, Computational Mechanics, vol.46, issue.6, pp.455-470, 2010. ,
Computational Electrodynamics. The Finite-Difference Time-Domain Method, 1995. ,
Double sweep preconditioner for optimized Schwarz methods applied to the Helmholtz problem, J. Comput. Phys, vol.266, pp.171-190, 2014. ,
Overview of the discontinuous enrichment method, the ultra-weak variational formulation, and the partition of unity method for the acoustic scattering in the medium frequency regime and performance comparisons, International Journal for Numerical Methods in Engineering, vol.89, pp.403-417, 2012. ,
Méthodes de Sous-Structuration et de Décomposition de Domaine pour la Résolution des Équations de Maxwell : Application au Rayonnement d'antenne dans un Environnement Complexe, 2006. ,
The adaptive cross approximation algorithm for accelerated method of moments computations of emc problems, IEEE transactions on electromagnetic compatibility, vol.47, issue.4, pp.763-773, 2005. ,
Continuous interior penalty finite element method for helmholtz equation with high wave number: One dimensional analysis ,
