DDFV Schemes for semiconductors energy-transport models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a Discrete Duality Finite Volume scheme (DDFV for short) for an energy transport model for semiconductors. As in the continuous case, thanks to a change of variables into the so-called "entropic variables", we are able to prove a discrete entropy-dissipation estimate, which gives a priori estimates for the problem. We perform some numerical tests for the 2D ballistic diode, by comparing the Chen model and the Lyumkis model.
proceedings_lissoni.pdf (863.3 Ko) Télécharger le fichier
hal-02899787 , version 1 (15-07-2020)
  • HAL Id : hal-02899787 , version 1
Giulia Lissoni. DDFV Schemes for semiconductors energy-transport models. ALGORITMY 2020 - Conference on Scientific Computing, Sep 2020, Podbanske, Slovakia. ⟨hal-02899787⟩
74 Consultations
81 Téléchargements
