Privately Outsourcing Exponentiation to a Single Server: Cryptanalysis and Optimal Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2021
We address the problem of speeding up group computations in cryptography using a single untrusted computational resource. We analyze the security of two efficient protocols for securely outsourcing (multi-)exponentiations. We show that the schemes do not achieve the claimed security guarantees and we present practical polynomial-time attacks on the delegation protocols which allow the un-trusted helper to recover part (or the whole) of the device's secret inputs. We then provide simple constructions for outsourcing group exponentiations in different settings (e.g. public/secret, fixed/variable bases and public/secret exponents). Finally, we prove that our attacks are unavoidable if one wants to use a single untrusted computational resource and to limit the computational cost of the limited device to a constant number of (generic) group operations. In particular, we show that our constructions are actually optimal in terms of operations in the underlying group.
manuscript.pdf (544.8 Ko) Télécharger le fichier
hal-02899803 , version 1 (15-07-2020)
Celine Chevalier, Fabien Laguillaumie, Damien Vergnaud. Privately Outsourcing Exponentiation to a Single Server: Cryptanalysis and Optimal Constructions. Algorithmica, 2021, 83 (1), pp.72-115. ⟨10.1007/s00453-020-00750-2⟩. ⟨hal-02899803⟩
183 Consultations
222 Téléchargements
