Recognition of Laban Effort Qualities from Hand Motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maxime Garcia
  • Fonction : Auteur
  • PersonId : 21249
  • IdHAL : magarcia
Rémi Ronfard
In this paper, we conduct a study for recognizing motion qualities in hand gestures using virtual reality trackers attached to the hand. From this 6D signal, we extract Euclidean, equi-affine and moving frame features and compare their effectiveness in the task of recognizing Laban Effort qualities. Our experimental results reveal that equi-affine features are highly discriminant features for this task. We also compare two classification methods on this task. In the first method, we trained separate HMM models for the 6 Laban Effort qualities (light, strong, sudden, sustained, direct, indirect). In the second method, we trained separate HMM models for the 8 Laban motion verbs (dab, glide, float, flick, thrust, press, wring, slash) and combined them to recognize individual qualities. In our experiments, the second method gives improved results. Together, those findings suggest that low-dimensional signals from VR trackers can be used to predict motion qualities with reasonable precision.
Laban_Motion_Qualities_Classification_Author.pdf (2.28 Mo) Télécharger le fichier
MOCO_2020_Presentation.pdf (2.75 Mo) Télécharger le fichier
Format : Figure, Image
Format : Présentation
hal-02899999 , version 1 (15-07-2020)
Maxime Garcia, Rémi Ronfard. Recognition of Laban Effort Qualities from Hand Motion. MOCO'20 - 7th International Conference on Movement and Computing, Jul 2020, Jersey City/ Virtual, United States. pp.1-8, ⟨10.1145/3401956.3404227⟩. ⟨hal-02899999⟩
263 Consultations
637 Téléchargements
