Cure: Strong semantics meets high availability and low latency, Int. Conf. on Distributed Comp. Sys. (ICDCS), pp.405-414, 2016. ,
Pure operation-based replicated data types, arXiv Computing Research Repository (CoRR), 2017. ,
Clock-SI: Snapshot isolation for partitioned data stores using loosely synchronized clocks, Symp. on Reliable Dist. Sys. (SRDS), pp.173-184, 2013. ,
Access control for weakly consistent replicated information systems, Gilles Barthe, Evangelos P. Markatos, and Pierangela Samarati, vol.9871, pp.82-97, 2016. ,
