Consistency and asymptotic normality of some subspace algorithms for systems without observed inputs, vol.35, pp.1243-1254, 1999. ,
Analysis of the asymptotic properties of the MOESP type of subspace algorithms, Automatica, vol.36, issue.4, pp.497-509, 2000. ,
Single sample modal identification of a nonstationary stochastic process, IEEE Transactions on Automatic Control, vol.30, issue.1, pp.66-74, 1985. ,
Nonstationary consistency of subspace methods, IEEE Transactions on Automatic Control, vol.52, issue.6, pp.974-984, 2007. ,
Persistence of excitation conditions and the convergence of adaptive schemes, IEEE Transactions on Information Theory, vol.30, issue.2, pp.183-191, 1984. ,
, Statistical Inference. Cengage Learning, 2001.
The asymptotic variance of subspace estimates, Journal of Econometrics, vol.118, issue.1, pp.257-291, 2004. ,
Consistency and relative efficiency of subspace methods, Automatica, issue.12, pp.1865-1875, 1995. ,
Multiorder covariance computation for estimates in stochastic subspace identification using QR decompositions, IFAC Proceedings Volumes, vol.47, pp.9498-9503, 2014. ,
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, pp.346-366, 2013. ,
Improving the numerical efficiency of the B and D estimates produced by the combined deterministic-stochastic subspace identification algorithms, 42nd IEEE Conference on Decision and Control, 2003. ,
, , 2013.
, Covariance-driven subspace identification: A complete input-output approach, Journal of Sound and Vibration, vol.332, issue.26, pp.7000-7017
The differentiation of pseudo-inverses and nonlinear least squares problems whose variables separate, SIAM Journal on Numerical Analysis, vol.10, issue.2, pp.413-432, 1973. ,
Asymptotic variance analysis of subspace identification methods, 12th IFAC Symposium on System Identification (SYSID 2000), vol.33, pp.21-23, 2000. ,
Consistency analysis of subspace identification methods based on a linear regression approach, Automatica, vol.37, issue.1, pp.81-89, 2001. ,
Canonical variate analysis in identification, filtering, and adaptive control, 29th IEEE Conference on Decision and Control, 1990. ,
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, issue.C, pp.1-27, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01328435
Uncertainty calculation in (operational) modal analysis. Mechanical Systems and Signal Processing, vol.21, pp.2359-2373, 2007. ,
A novel subspace identification approach with enforced causal models, Automatica, issue.12, pp.2043-2053, 2005. ,
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
N4SID: Subspace algorithms for the identification of combined deterministic-stochastic systems, Automatica, vol.30, issue.1, pp.75-93, 1994. ,
Subspace Identification for Linear Systems, 1996. ,
Subspace model identification part 3. analysis of the ordinary output-error state-space model identification algorithm, International Journal of Control, vol.58, issue.3, pp.555-586, 1993. ,
Subspace model identification part 1. The output-error state-space model identification class of algorithms, International Journal of Control, vol.56, issue.5, pp.1187-1210, 1992. ,
Analysis of state space system identification methods based on instrumental variables and subspace fitting, Automatica, vol.33, issue.9, pp.1603-1616, 1997. ,
Asymptotic analysis of subspace-based datadriven residual for fault detection with uncertain reference, 10th IFAC Symposium on Fault Detection, Supervision and Safety for Technical Processes (SAFEPROCESS), vol.51, pp.414-419, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01886626
