Towards robust statistical damage localization via model-based sensitivity clustering, Mechanical Systems and Signal Processing, vol.134, p.106341, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02293021
Statistical model-based damage localization: a combined subspace-based and substructuring approach. Structural Control and Health Monitoring, vol.15, pp.857-875, 2008. ,
, , 2000.
, Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, pp.101-109
Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios, Journal of Sound and Vibration, vol.275, issue.3-5, pp.769-794, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00071940
The asymptotic local approach to change detection and model validation, IEEE Transactions on Automatic Control, vol.32, issue.7, pp.583-592, 1987. ,
URL : https://hal.archives-ouvertes.fr/inria-00075990
Practical identifiability of asm2d parameters-systematic selection and tuning of parameter subsets, Water research, vol.36, issue.16, pp.4113-4127, 2002. ,
Practical identifiability analysis of large environmental simulation models, Water Resources Research, issue.37, pp.1015-1030, 2001. ,
Parameter set selection via clustering of parameters into pairwise indistinguishable groups of parameters, Industrial & Engineering Chemistry Research, vol.48, issue.13, pp.6000-6009, 2009. ,
Fault detection, isolation and quantification from Gaussian residuals with application to structural damage diagnosis, Annual Reviews in Control, vol.42, pp.244-256, 2016. ,
, Pattern classification, 2012.
Finite element model updating in structural dynamics, vol.38, 2013. ,
Selection of model parameters for off-line parameter estimation, IEEE Transactions on Control Systems Technology, vol.12, issue.3, pp.402-412, 2004. ,
Minimum detectable damage for stochastic subspace-based methods, Proc. of IOMAC -International Operational Modal Analysis Conference, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02142994
Selection of parameters for updating in on-line models, Industrial & Engineering Chemistry Research, vol.40, issue.18, pp.3936-3950, 2001. ,
A subspace fitting method for identification of linear state-space models, IEEE Transactions on Automatic Control, vol.40, issue.2, pp.311-316, 1995. ,
Subset selection in identification, and application to speed and parameter estimation for induction machines, Proceedings of International Conference on Control Applications, pp.991-997, 1995. ,
Qualitative and quantitative experiment design for phenomenological models -a survey, Automatica, vol.26, issue.2, pp.195-213, 1990. ,
A procedure for selcting best identifiable parameters in calbrating activated sludge model no.1 to full-scale plant data. Water science and technology, vol.36, pp.69-79, 1997. ,
Modeling ethylene/butene copolymerization with multi-site catalysts: Parameter estimability and experimental design, Polymer Reaction Engineering, vol.11, issue.3, pp.563-588, 2003. ,
