The revisited knockoffs method for variable selection in L 1 -penalized regressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Statistics - Simulation and Computation Année : 2020
We consider the problem of variable selection in regression models. In particular, we are interested in selecting explanatory covariates linked with the response variable and we want to determine which covariates are relevant, that is which covariates are involved in the model. In this framework, we deal with L 1-penalized regression models. To handle the choice of the penalty parameter to perform variable selection, we develop a new method based on the knockoffs idea. This revisited knockoffs method is general, suitable for a wide range of regressions with various types of response variables. Besides, it also works when the number of observations is smaller than the number of covariates and gives an order of importance of the covariates. Finally, we provide many experimental results to corroborate our method and compare it with other variable selection methods.
RevKO-1.pdf (575.26 Ko) Télécharger le fichier
hal-02903837 , version 1 (18-01-2021)
Anne Gégout-Petit, Aurélie Gueudin-Muller, Clémence Karmann. The revisited knockoffs method for variable selection in L 1 -penalized regressions. Communications in Statistics - Simulation and Computation, 2020, ⟨10.1080/03610918.2020.1775850⟩. ⟨hal-02903837⟩
86 Consultations
136 Téléchargements
