Graph integration of structured, semistructured and unstructured data for data journalism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2020
Nowadays, journalism is facilitated by the existence of large amounts of digital data sources, including many Open Data ones. Such data sources are extremely heterogeneous, ranging from highly struc-tured (relational databases), semi-structured (JSON, XML, HTML), graphs (e.g., RDF), and text. Journalists (and other classes of users lacking advanced IT expertise, such as most non-governmental-organizations, or small public administrations) need to be able to make sense of such heterogeneous corpora, even if they lack the ability to de ne and deploy custom extract-transform-load work ows. These are di cult to set up not only for arbitrary heterogeneous inputs , but also given that users may want to add (or remove) datasets to (from) the corpus. We describe a complete approach for integrating dynamic sets of heterogeneous data sources along the lines described above: the challenges we faced to make such graphs useful, allow their integration to scale, and the solutions we proposed for these problems. Our approach is implemented within the ConnectionLens system; we validate it through a set of experiments.
paper.pdf (1.14 Mo) Télécharger le fichier
hal-02904797 , version 1 (22-07-2020)
hal-02904797 , version 2 (29-10-2020)
Oana Balalau, Catarina Conceição, Helena Galhardas, Ioana Manolescu, Tayeb Merabti, et al.. Graph integration of structured, semistructured and unstructured data for data journalism. 36ème Conférence sur la Gestion de Données – Principes, Technologies et Applications (informal publication only), 2020. ⟨hal-02904797v2⟩
345 Consultations
259 Téléchargements
