A closed form solution to describe infusion of resin under vacuum in deformable fibrous porous media, Modelling Simul. Mater. Sci. Eng, vol.12, pp.191-204, 2004. ,
Manufacturing techniques for polymer matrix composites (PMCs), 2012. ,
Resin transfer moulding, 1997. ,
, Composites on the road to the big time? Reinforced Plastics, vol.47, pp.33-36, 2003.
Use of medial axis to find optimal channel designs to reduce mold filling time in resin transfer molding, Compos A Appl Sci Manuf, vol.95, pp.161-72, 2017. ,
Study on high-speed RTM to reduce the impregnation time of carbon/epoxy composites, Composite Structures, vol.119, pp.50-58, 2015. ,
Plastic transfer molding techniques for the production of fiber reinforced plastic structures, US Patent No, p.215, 1990. ,
Simulation and experimental validation of flow flooding chamber method of resin delivery in liquid composite molding, Compos Part A Appl Sci Manuf, vol.38, pp.2131-2172, 2007. ,
Liquid composite molding control methodologies using vacuum induced preform relaxation, Compos Part A Appl Sci Manuf, vol.42, pp.57-65, 2011. ,
Experimental analysis of mold filling in vacuum assisted compression resin transfer molding, J. Reinf Plast Comp, vol.31, pp.1630-1637, 2012. ,
Innovating problem solving in power quality devices: a survey based on dynamic voltage restorer case, Renew Sustain Energy Rev, vol.70, pp.1207-1216, 2017. ,
TRIZ-based approach for accelerating innovation in chemical engineering, Chemical Engineering Research and Design, vol.103, pp.25-31, 2015. ,
Conceptual design of automobile engine rubber mounting composite using TRIZ-Morphological chart-analytic network process technique, Defence Technology, vol.14, issue.4, pp.268-277, 2018. ,
Application of TRIZ approach to machine vibration condition monitoring problems, Mechanical Systems and Signal Processing, vol.41, pp.328-334, 2013. ,
Research on developing environmental protection industry based on TRIZ theory, Procedia Environmental Sciences, vol.2, pp.1326-1334, 2010. ,
Lois d'evolution de TRiZ pour la conception des futures generations des produits : Proposition d'un modele, 2012. ,
URL : https://hal.archives-ouvertes.fr/pastel-00691854
A review of TRIZ, and its benefits and challenges in practice, pp.30-37, 2013. ,
Dilemma of a Radical Innovation -A New View on the Law of Transition to a Micro-Level, TRIZ journal, 1999. ,
Applying the Law of the Completeness of a Technological System to Formulate a Problem, TRIZ journal, 2007. ,
Application of FMEA method in product development stage, Academic Journal of Manufacturing Engineering, vol.10, issue.3, pp.12-19, 2012. ,
Modeling a hybrid-compact design matrix for new product innovation, Computers and Industrial Engineering, vol.107, pp.345-359, 2017. ,
Experience capitalization to support decision making in inventive problem solving, Computers in Industry, vol.101, pp.25-40, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02047105
Adaptation of TRIZ contradiction matrix for solving problems in process engineering, Chemical Engineering Research and Design, vol.103, pp.3-10, 2015. ,
Simulation of articulated compression resin transfer molding, The 8th International Conference on Flow Processes in Composite Materials (FPCM8) Douai, 2006. ,
Numerical study on filling process in progressive compression method, 2017. ,
Flexible injection: a novel LCM technology for low cost manufacturing of high performance composites. Part I: experimental investigation, Proceedings, vol.9, p.34, 2008. ,
