The Aronson-Bénilan Estimate in Lebesgue Spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In a celebrated three-pages long paper in 1979, Aronson and Bénilan obtained a remarkable estimate on second order derivatives for the solution of the porous media equation. Since its publication, the theory of porous medium flow has expanded relentlessly with applications including thermodynamics, gas flow, ground water flow as well as ecological population dynamics. The purpose of this paper is to clarify the use of recent extensions of the Aronson and Bénilan estimate in L p spaces, of some modifications and improvements, as well as to show certain limitations of their strategy.
final.pdf (618.81 Ko) Télécharger le fichier
hal-02909140 , version 1 (30-07-2020)
  • HAL Id : hal-02909140 , version 1
Giulia Bevilacqua, Benoît Perthame, Markus Schmidtchen. The Aronson-Bénilan Estimate in Lebesgue Spaces. 2020. ⟨hal-02909140⟩
111 Consultations
200 Téléchargements
