Piecewise estimation of R0 by a simple SEIR model. Application to COVID-19 in French regions and departments until June 30, 2020 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
The estimation of R0, the so-called "basic reproductive ratio", of the COVID-19 pandemic is of particular importance to help decision-makers take the necessary safeguard measures to protect the population. In this work, we examine a method based on the successive estimation of R0 over 3 non-overlapping periods (before lockdown, during lockdown and after). The approach is based on a variant of the, simple but flexible, SEIR compartmental model that allows to exploit the number of recovered individuals that are reported in the daily database published by national health agencies. The results of the approach is analysed w.r.t. data from France, at two levels of geographical subdivisions, i.e. the 13 regions and 96 departments that make up the metropolitan territory.
R0_ConfineCOVID.pdf (18.71 Mo) Télécharger le fichier
hal-02910202 , version 1 (01-08-2020)
hal-02910202 , version 2 (02-09-2020)
  • HAL Id : hal-02910202 , version 2
Stéphane Derrode, Romain Gauchon, Nicolas Ponthus, Christophe Rigotti, Catherine Pothier, et al.. Piecewise estimation of R0 by a simple SEIR model. Application to COVID-19 in French regions and departments until June 30, 2020. [Research Report] LIRIS UMR CNRS 5205; Ecole centrale de lyon; INSA LYON; Université Lyon 1 - Claude Bernard. 2020. ⟨hal-02910202v2⟩
476 Consultations
281 Téléchargements
