Manufacture and characterisation of thin flat and curved auxetic foam sheets, physica status solidi (b), vol.249, issue.7, pp.1315-1321, 2012. ,
Statistical aspects of fuzzy monotone set-valued stochastic processes. Application to birth-and-growth processes, Fuzzy Sets and Systems, vol.160, issue.21, pp.3140-3151, 2009. ,
Integration in a dynamical stochastic geometric framework, ESAIM: Probability and Statistics, vol.15, pp.402-416, 2011. ,
Homogenization and Two-Scale Convergence, SIAM Journal on Mathematical Analysis, vol.23, issue.6, pp.1482-1518, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01111805
How to determine composite material properties using numerical homogenization, Computational Materials Science, vol.83, pp.488-495, 2014. ,
Some variance reduction methods for numerical stochastic homogenization, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.374, issue.2066, p.20150168, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01196499
Approximations of effective coefficients in stochastic homogenization, Annales de l?Institut Henri Poincare (B) Probability and Statistics, vol.40, issue.2, pp.153-165, 2004. ,
Microporous materials with negative Poisson's ratios. I. Microstructure and mechanical properties, Journal of Physics D: Applied Physics, vol.22, issue.12, pp.1877-1882, 1989. ,
Fabrication methods for auxetic foams, Journal of Materials Science, vol.32, issue.22, pp.5945-5953, 1997. ,
Stochastic Geometry and its Applications, 2013. ,
Computational prediction of new auxetic materials, Nature Communications, vol.8, issue.1, pp.1-8, 2017. ,
Random auxetics from buckling fibre networks, Nature Communications, vol.10, issue.1, pp.1-8, 2019. ,
Symmetry classes for elasticity tensors, Journal of Elasticity, vol.43, issue.2, pp.81-108, 1996. ,
Numerical Analysis of the Mechanical Properties of 3D Random Voronoi Structures With Negative Poisson's Ratio, physica status solidi (b), vol.256, issue.7, p.1800539, 2019. ,
Compatibility in microstructural optimization for additive manufacturing, Additive Manufacturing, vol.26, pp.65-75, 2019. ,
Cellular solids: structure and properties, 1999. ,
Auxetic perforated mechanical metamaterials with randomly oriented cuts, Advanced materials, vol.28, issue.2, pp.385-389, 2016. ,
Disordered auxetic networks with no reentrant polygons, Physical Review B, vol.98, issue.10, p.100101, 2018. ,
Acoustic absorption behaviour of an open-celled aluminium foam, Journal of Physics D: Applied Physics, vol.36, issue.3, pp.294-302, 2003. ,
Cellular structure design based on free material optimization under connectivity control, Computer-Aided Design, vol.127, p.102854, 2020. ,
Determination of the size of the representative volume element for random composites: statistical and numerical approach, International Journal of Solids and Structures, vol.40, issue.13-14, pp.3647-3679, 2003. ,
Auxetic mechanical metamaterials, RSC Advances, vol.7, issue.9, pp.5111-5129, 2017. ,
Determination of the average characteristics of elastic frameworks, Journal of Applied Mathematics and Mechanics, vol.49, issue.6, pp.739-745, 1985. ,
Design of polymeric auxetic matrices for improved mechanical coupling in lead-free piezocomposites, Smart Materials and Structures, vol.29, issue.5, p.54002, 2020. ,
Inverse-designed spinodoid metamaterials, npj Computational Materials, vol.6, issue.1, pp.1-10, 2020. ,
Foam Structures with a Negative Poisson's Ratio, Science, vol.235, issue.4792, pp.1038-1040, 1987. ,
Negative-Poisson's-ratio materials: auxetic solids. Annual review of materials research, vol.47, pp.63-81, 2017. ,
Preface, Principles of Tissue Engineering, p.xli, 2020. ,
Negative Poisson?s ratio in 2D Voronoi cellular solids by biaxial compression: a numerical study, Journal of Materials Science, vol.51, issue.14, pp.7029-7037, 2016. ,
Realizing negative Poisson's ratio in spring networks with close-packed lattice geometries, Physical Review Materials, vol.3, issue.5, p.55607, 2019. ,
Procedural voronoi foams for additive manufacturing, ACM Transactions on Graphics, vol.35, issue.4, pp.1-12, 2016. ,
Star-shaped metrics for mechanical metamaterial design, ACM Transactions on Graphics, vol.38, issue.4, pp.1-13, 2019. ,
Auxeticity and stiffness of random networks: Lessons for the rational design of 3D printed mechanical metamaterials, Applied Physics Letters, vol.115, issue.2, p.021901, 2019. ,
The Closest Elastic Tensor of Arbitrary Symmetry to an Elasticity Tensor of Lower Symmetry, Journal of Elasticity, vol.85, issue.3, pp.215-263, 2006. ,
On Bayesian Methods for Seeking the Extremum, Optimization Techniques IFIP Technical Conference, pp.400-404, 1975. ,
The isotropic material closest to a given anisotropic material, Journal of Mechanics of Materials and Structures, vol.1, issue.2, pp.223-238, 2006. ,
Spatial Tessellations, 2000. ,
Directed aging, memory, and nature?s greed, Science Advances, vol.5, issue.12, p.eaax4215, 2019. ,
Extreme mechanical resilience of self-assembled nanolabyrinthine materials, Proceedings of the National Academy of Sciences, vol.117, issue.11, pp.5686-5693, 2020. ,
Negative Poisson?s ratio in two-dimensional honeycomb structures, npj Computational Materials, vol.6, issue.1, pp.1-6, 2020. ,
Density scaling in the mechanics of a disordered mechanical meta-material, Applied Physics Letters, vol.114, issue.11, p.111902, 2019. ,
Ideal isotropic auxetic networks from random networks, Soft Matter, vol.15, issue.40, pp.8084-8091, 2019. ,
Auxetic metamaterials from disordered networks, Proceedings of the National Academy of Sciences, vol.115, issue.7, pp.1384-1390, 2018. ,
Auxetic metamaterials and structures: a review, Smart Materials and Structures, vol.27, issue.2, p.023001, 2018. ,
Inverse design of discrete mechanical metamaterials, Physical Review Materials, vol.3, issue.9, p.95201, 2019. ,
Three Decades of Auxetics Research ? Materials with Negative Poisson's Ratio: A Review, Advanced Engineering Materials, vol.18, issue.11, pp.1847-1870, 2016. ,
Computer-aided design of porous artifacts, Computer-Aided Design, vol.37, issue.3, pp.339-353, 2005. ,
Random sequential adsorption: relationship to dead leaves and characterization of variability, Journal of Statistical Physics, vol.100, issue.5/6, pp.969-979, 2000. ,
Numerical determination of representative volumes for granular materials, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.30-32, pp.3221-3238, 2004. ,
Stochastic modeling of mesoscopic elasticity random field, Mechanics of Materials, vol.93, pp.1-12, 2016. ,
Topology optimization of multi-material negative Poisson?s ratio metamaterials using a reconciled level set method, Computer-Aided Design, vol.83, pp.15-32, 2017. ,
Lehrbuch der Kristallphysik (mit Ausschluss der Kristalloptik). By Woldemar Voigt. Pp. xxiv + 964, with 213 text-figures and 1 table. (Leipzig and Berlin: B. G. Teubner. 1910. Price 30 marks.), Mineralogical Magazine and Journal of the Mineralogical Society, vol.16, issue.75, pp.253-253, 1912. ,
Random Sequential Addition of Hard Spheres to a Volume, The Journal of Chemical Physics, vol.44, issue.10, pp.3888-3894, 1966. ,
Review on auxetic materials, Journal of Materials Science, vol.39, issue.10, pp.3269-3279, 2004. ,
Numerically-aided 3D printed random isotropic porous materials approaching the Hashin-Shtrikman bounds, Composites Part B: Engineering, vol.156, pp.344-354, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01875669
