Algebraic geometry for scientists and engineers, 1990. ,
Modular algorithms for computing Gröbner bases, J. Symbolic Comput, vol.35, issue.4, pp.403-419, 2003. ,
The use of bad primes in rational reconstruction, Math. Comp, vol.84, issue.296, pp.3013-3027, 2015. ,
Local to global algorithms for the Gorenstein adjoint ideal of a curve, Algorithmic and experimental methods in algebra, geometry, and number theory, pp.51-96, 2017. ,
Parallel algorithms for normalization, J. Symbolic Comput, vol.51, pp.99-114, 2013. ,
The Magma algebra system. I: The user language, J. Symb. Comput, vol.24, issue.3-4, pp.235-265, 1997. ,
Fundamental group for some cuspidal curves, Bull. London Math. Soc, vol.31, issue.2, pp.136-142, 1999. ,
An algorithm for computing the integral closure, J. Symbolic Comput, vol.26, issue.3, pp.273-277, 1998. ,
Local analytic geometry. Basic theory and applications, 2000. ,
The normalization: a new algorithm, implementation and comparisons, Computational methods for representations of groups and algebras, vol.173, pp.177-185, 1997. ,
Singular 4-0-2 -A computer algebra system for polynomial computations, 2015. ,
Algorithmes pour la décomposition primaire des idéaux polynomiaux de dimension nulle donnés e? evaluation, 2008. ,
Commutative algebra. With a view toward algebraic geometry, 1995. ,
Implementing the round four maximal order algorithm, J. Théor. Nombres Bordeaux, vol.6, issue.1, pp.39-80, 1994. ,
Unter Mitarbeit von O. Riemenschneider, 1971. ,
Normalization of rings, J. Symbolic Comput, vol.45, issue.9, pp.887-901, 2010. ,
A Singular introduction to commutative algebra, 2007. ,
Éléments de géométrie algébrique. IV.Étude locale des schémas et des morphismes de schémas, III. Inst. HautesÉtudes Sci. Publ. Math, issue.28, p.255, 1966. ,
Maple 18 Programming Guide, 2014. ,
Algebraic function fields and codes, 2009. ,
An algorithm for computing an integral basis in an algebraic function field, J. Symbolic Comput, vol.18, issue.4, pp.353-363, 1994. ,
Algebraic curves, 1978. ,
