Computation of real radicals of polynomial ideals, Prog. Math, vol.109, pp.1-20, 1993. ,
Semidefinite Optimization and Convex Algebraic Geometry, MOS-SIAM Series on Optimization, vol.13, 2012. ,
Learning algebraic varieties from samples, Revista Matematica Complutense, vol.31, pp.545-593, 2018. ,
On the geometry of the set of symmetric matrices with repeated eigenvalues, Arnold Math. J, vol.4, pp.423-443, 2018. ,
, Random points on an algebraic manifold
, On the local stability of semidefinite relaxations
The geometry of SDP-exactness in quadratic optimization, Math. Program, pp.1-30, 2019. ,
The bottleneck degree of algebraic varieties, SIAM J. Applied Algebra and Geometry, 2020. ,
The Euclidean distance degree of an algebraic variety, Found. Comput. Math, vol.16, pp.99-149, 2016. ,
Sampling real algebraic varieties for topological data analysis, 18th IEEE Intern, Machine Learning and Applications (ICMLA 2019) ,
Computing real radicals and S -radicals of polynomial systems, J. Symbolic Computation, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02388168
, Intersection Theory, 1984.
, Introduction to Toric Varieties, 1993.
A generalization of the Eckart-Young-Mirsky matrix approximation theorem, Linear Algebra Appl, vol.88, pp.317-327, 1987. ,
, Macaulay2, a software system for research in algebraic geometry
Offset hypersurfaces and persistent homology of algebraic varieties, Computer Aided Geom. Design, p.101767, 2019. ,
A certificate for semidefinite relaxations in computing positive-dimensional real radical ideals, J. Symbolic Computation, vol.72, pp.1-20, 2016. ,
, The distance function from a real algebraic variety
, Algebraic Topology, 1966.
