CERTIFICATION FOR POLYNOMIAL SYSTEMS VIA SQUARE SUBSYSTEMS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider numerical certification of approximate solutions to a system of polynomial equations with more equations than unknowns by first certifying solutions to a square subsystem. We give several approaches that certifiably select which are solutions to the original overdetermined system. These approaches each use different additional information for this certification, such as liaison, Newton-Okounkov bodies, or intersection theory. They may be used to certify individual solutions, reject nonsolutions, or certify that we have found all solutions.
10.pdf (405.72 Ko) Télécharger le fichier
hal-02912296 , version 1 (05-08-2020)
  • HAL Id : hal-02912296 , version 1
Timothy Duff, Nickolas Hein, Frank Sottile. CERTIFICATION FOR POLYNOMIAL SYSTEMS VIA SQUARE SUBSYSTEMS. MEGA 2019 - International Conference on Effective Methods in Algebraic Geometry, Jun 2019, Madrid, Spain. ⟨hal-02912296⟩
Collections
MEGA MEGA2019
38 Consultations
63 Téléchargements
