Cost Reduction and Evaluation of a Temporary Faults-Detecting Technique, Design, Automation, and Test in Europe, pp.423-438, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00013756
An In-Depth and Black-Box Characterization of the Effects of Clock Glitches on 8-bit MCUs, Workshop on Fault Diagnosis and Tolerance in Cryptography, 2011. ,
The Sorcerer's Apprentice Guide to Fault Attacks, Proceedings of the IEEE, vol.94, issue.2, pp.370-382, 2006. ,
Countermeasures Against Fault Attacks on Software Implemented AES: Effectiveness and Cost, 5th Workshop on Embedded Systems Security, 2010. ,
Compilation of a Countermeasure Against Instruction-Skip Fault Attacks, Proceedings of the Third Workshop on Cryptography and Security in Computing Systems, pp.1-6, 2016. ,
URL : https://hal.archives-ouvertes.fr/cea-01296572
Automated Software Protection for the Masses Against Side-Channel Attacks, ACM Trans. Archit. Code Optim, vol.15, issue.4, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01927625
Security Evaluation of Different AES Implementations Against Practical Setup Time Violation Attacks in FPGAs, IEEE International Workshop on Hardware-Oriented Security and Trust, pp.15-21, 2009. ,
Somayeh Sardashti, et al. The gem5 simulator, ACM SIGARCH computer architecture news, vol.39, issue.2, pp.1-7, 2011. ,
Shaping the Glitch: Optimizing Voltage Fault Injection Attacks, IACR Transactions on Cryptographic Hardware and Embedded Systems, pp.199-224, 2019. ,
When Good Instructions go Bad: Generalizing Return-Oriented Programming to RISC, Proceedings of the 15th ACM conference on Computer and communications security, pp.27-38, 2008. ,
Let's Shock Our IoT's Heart: ARMv7-M Under (Fault) Attacks, Proceedings of the 13th International Conference on Availability, Reliability and Security, vol.33, pp.1-33, 2018. ,
Accuracy Evaluation of gem5 Simulator System, 7th International Workshop on Reconfigurable and Communication-Centric Systems-on-Chip (ReCoSoC), pp.1-7, 2012. ,
, Kostas Papagiannopoulos, and Niek Timmers. Instruction Duplication: Leaky and not Too Fault-Tolerant! In International Conference on Smart Card Research and Advanced Applications, pp.160-179, 2017.
Universality in Elementary Cellular Automata, Complex Systems, p.15, 2004. ,
A Concrete View of Rule 110 Computation, Electronic Proceedings in Theoretical Computer Science, vol.1, pp.31-55, 2009. ,
Isomeron: Code Randomization Resilient to (Just-In-Time) Return-Oriented Programming, NDSS, 2015. ,
Securing a Compiler Transformation, Formal Methods in System Design, vol.53, issue.2, pp.166-188, 2018. ,
On Second-Order Fault Analysis Resistance for CRT-RSA Implementations, IFIP International Workshop on Information Security Theory and Practices, pp.68-83, 2009. ,
A Multiple-Fault Injection Attack by Adaptive Timing Control Under Black-Box Conditions and a Countermeasure, International Workshop on Constructive Side-Channel Analysis and Secure Design, 2014. ,
An Efficient Countermeasure Against Fault Sensitivity Analysis Using Configurable Delay Blocks, Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.95-102, 2012. ,
Fault Attacks for CRT Based RSA: New Attacks, New Results and New Countermeasures, Proceedings of the 1st IFIP International Conference on Information Security Theory and Practices: Smart Cards, Mobile and Ubiquitous Computing Systems, WISTP'07, pp.215-228, 2007. ,
New Differential Fault Analysis on AES Key Schedule: Two Faults are Enough, International Conference on Smart Card Research and Advanced Applications, pp.48-60, 2008. ,
Electromagnetic Security Tests for SoC, 2016 IEEE International Conference on Electronics, Circuits and Systems (ICECS), 2016. ,
Electromagnetic Fault Injection: Towards a Fault Model on a 32-bit Microcontroller, Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.77-88, 2013. ,
URL : https://hal.archives-ouvertes.fr/emse-00871218
Formal Verification of a Software Countermeasure Against Instruction Skip Attacks, Journal of Cryptographic Engineering, vol.4, issue.3, pp.145-156, 2014. ,
URL : https://hal.archives-ouvertes.fr/emse-00869509
Error Detection by Duplicated Instructions in Super-Scalar Processors, IEEE Transactions on Reliability, vol.51, issue.1, pp.63-75, 2002. ,
, Compiler-Assisted Loop Hardening Against Fault Attacks. ACM Trans. Archit. Code Optim, vol.14, issue.4, 2017.
A First ISA-Level Characterization of EM Pulse Effects on Superscalar Microarchitectures, ARES 2019 -14th International Conference on Availability, Reliability and Security, vol.7, pp.1-7, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02373088
SWIFT: Software Implemented Fault Tolerance, International Symposium on Code Generation and Optimization, 2005. ,
High Precision Fault Injections on the Instruction Cache of ARMv7-M Architectures, 2015 IEEE International Symposium on Hardware Oriented Security and Trust (HOST), pp.62-67, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208378
The Geometry of Innocent Flesh on the Bone: Return-into-libc Without Function Calls (on the x86), Proceedings of the 14th ACM conference on Computer and communications security, pp.552-561, 2007. ,
Optical Fault Induction Attacks, International workshop on cryptographic hardware and embedded systems, pp.2-12, 2002. ,
DFA Mechanism on the AES Key Schedule, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC 2007), pp.62-74, 2007. ,
Controlling PC on ARM Using Fault Injection, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC), pp.25-35, 2016. ,
Multi Fault Laser Attacks on Protected CRT-RSA, Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.75-86, 2010. ,
Software Fault Resistance is Futile: Effective Single-Glitch Attacks, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC), pp.47-58, 2016. ,
Efficiency of a Glitch Detector Against Electromagnetic Fault Injection, 2014 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.1-6, 2014. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01096047
Investigation of Timing Constraints Violation as a Fault Injection Means, 27th Conference on Design of Circuits and Integrated Systems (DCIS), p.11, 2012. ,
URL : https://hal.archives-ouvertes.fr/emse-00742652
