Impact of Receiver Non-idealities on a Full Duplex Spatial Modulation System Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Wireless Communications Letters Année : 2020
In this paper, we analyze, for the first time, the performance of a full-duplex system combined with spatial modulation technique in presence of the receiver non-idealities. IQ imbalance and phase noise are the two radio front-end mismatch factors that have been considered. The impact of the IQ imbalance on the bit error rate (BER) performance of the full-duplex spatial modulation (FDSM) system under different noise levels is investigated. An estimator has also been proposed for the self-interference cancellation (SIC) after the imperfect receiver. The results show that IQ imbalance does not significantly reduce system BER performance at low signal-to-noise ratios. Moreover, it is shown that the proposed estimator is able to maintain the system at an acceptable BER.
WCL2020-0861 (1).PDF (2.3 Mo) Télécharger le fichier
hal-02912329 , version 1 (05-08-2020)
Yanni Zhou, Florin Hutu, Guillaume Villemaud. Impact of Receiver Non-idealities on a Full Duplex Spatial Modulation System Performance. IEEE Wireless Communications Letters, 2020, 9 (12), pp.2083-2087. ⟨10.1109/LWC.2020.3013195⟩. ⟨hal-02912329⟩
119 Consultations
148 Téléchargements
