Real-Time Multi-SLAM System for Agent Localization and 3D Mapping in Dynamic Scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces a Wearable SLAM system that performs indoor and outdoor SLAM in real time. The related project is part of the MALIN challenge which aims at creating a system to track emergency response agents in complex scenarios (such as dark environments, smoked rooms, repetitive patterns, building floor transitions and doorway crossing problems), where GPS technology is insufficient or inoperative. The proposed system fuses different SLAM technologies to compensate the lack of robustness of each, while estimating the pose individually. LiDAR and visual SLAM are fused with an inertial sensor in such a way that the system is able to maintain GPS coordinates that are sent via radio to a ground station, for real-time tracking. More specifically, LiDAR and monocular vision technologies are tested in dynamic scenarios where the main advantages of each have been evaluated and compared. Finally, 3D reconstruction up to three levels of details is performed.
IROS_2020.pdf (9.59 Mo) Télécharger le fichier
Format : Figure, Image
hal-02913098 , version 1 (07-08-2020)
  • HAL Id : hal-02913098 , version 1
Pierre Alliez, Fabien Bonardi, Samia Bouchafa, Jean-Yves Didier, Hicham Hadj-Abdelkader, et al.. Real-Time Multi-SLAM System for Agent Localization and 3D Mapping in Dynamic Scenarios. IROS 2020 - International Conference on Intelligent Robots and Systems, Oct 2020, Las Vegas, NV, United States. ⟨hal-02913098⟩
618 Consultations
1107 Téléchargements
