Quantitative approximation of nonlinear Fokker-Planck equations with singular potential by interacting particle systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We propose a new approach to show quantitative estimates for solutions of nonlinear Fokker-Planck equations with singular potential by stochastic interacting particle systems. Our result only requires very weak regularity on the interaction kernel, including the Biot-Savart kernel, the family of Keller-Segel kernels in arbitrary dimension, and more generally singular Riesz kernels. The proof is based on a semigroup approach, and we also exploit the regularity of the solutions of the limiting equation.
GeneralKernel_Hal.pdf (588.19 Ko) Télécharger le fichier
hal-02914779 , version 1 (12-08-2020)
hal-02914779 , version 2 (12-11-2020)
hal-02914779 , version 3 (29-12-2020)
hal-02914779 , version 4 (27-06-2022)
  • HAL Id : hal-02914779 , version 1
Christian Olivera, Alexandre Richard, Milica Tomasevic. Quantitative approximation of nonlinear Fokker-Planck equations with singular potential by interacting particle systems. 2020. ⟨hal-02914779v1⟩
460 Consultations
509 Téléchargements
