Quantitative particle approximation of nonlinear Fokker-Planck equations with singular kernel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We propose a new approach to obtain quantitative convergence of moderately interacting particle systems to solutions of nonlinear Fokker-Planck equations with singular kernels. Our result only requires very weak regularity on the interaction kernel, including the Biot-Savart kernel, the family of Keller-Segel kernels in arbitrary dimension, and more generally singular Riesz kernels. This seems to be the first time that such quantitative convergence results are obtained in Lebesgue and Sobolev norms for the aforementioned kernels. In particular, this convergence holds locally in time for PDEs exhibiting a blow-up in finite time. The proof is based on a semigroup approach combined with stochastic calculus techniques, and we also exploit the regularity of the solutions of the limiting equation. Furthermore, we obtain well-posedness for the McKean-Vlasov SDEs involving these singular kernels and we prove the trajectorial propagation of chaos for the associated moderately interacting particle systems
GeneralKernel.pdf (616.44 Ko) Télécharger le fichier
hal-02914779 , version 1 (12-08-2020)
hal-02914779 , version 2 (12-11-2020)
hal-02914779 , version 3 (29-12-2020)
hal-02914779 , version 4 (27-06-2022)
  • HAL Id : hal-02914779 , version 2
Christian Olivera, Alexandre Richard, Milica Tomasevic. Quantitative particle approximation of nonlinear Fokker-Planck equations with singular kernel. 2020. ⟨hal-02914779v2⟩
462 Consultations
513 Téléchargements
