Gradual Discovery with Closure Structure of a Concept Lattice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An approximate discovery of closed itemsets is usually based on either setting a frequency threshold or computing a sequence of projections. Both approaches, being incremental, do not provide any estimate of the size of the next output and do not ensure that "more interesting patterns" will be generated first. We propose to generate closed item-sets incrementally, w.r.t. the size of the smallest (cardinality-minimal or minimum) generators and show that this approach (i) exhibits anytime property, and (ii) generates itemsets of decreasing quality.
CLA_2020_paper_19.pdf (817.87 Ko) Télécharger le fichier
hal-02915309 , version 1 (14-08-2020)
  • HAL Id : hal-02915309 , version 1
Tatiana Makhalova, Sergei O. Kuznetsov, Amedeo Napoli. Gradual Discovery with Closure Structure of a Concept Lattice. The 15th International Conference on Concept Lattices and Their Applications, Jun 2020, Tallinn, Estonia. ⟨hal-02915309⟩
99 Consultations
44 Téléchargements
