Decomposition of High Dimensional Aggregative Stochastic Control Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We consider the framework of high dimensional stochastic control problem, in which the controls are aggregated in the cost function. As first contribution we introduce a modified problem, whose optimal control is under some reasonable assumptions an ε-optimal solution of the original problem. As second contribution, we present a decentralized algorithm whose convergence to the solution of the modified problem is established. Finally, we study the application to a problem of coordination of energy consumption and production of domestic appliances.
DecompHighDimStoProb_17_9_2020.pdf (562.7 Ko) Télécharger le fichier
hal-02917014 , version 1 (18-08-2020)
hal-02917014 , version 2 (18-08-2020)
hal-02917014 , version 3 (17-09-2020)
hal-02917014 , version 4 (20-10-2021)
hal-02917014 , version 5 (02-03-2023)
  • HAL Id : hal-02917014 , version 3
Adrien Seguret, Clémence Alasseur, J Frédéric Bonnans, Antonio de Paola, Nadia Oudjane, et al.. Decomposition of High Dimensional Aggregative Stochastic Control Problems. 2020. ⟨hal-02917014v3⟩
706 Consultations
360 Téléchargements
