New interface
Preprints, Working Papers, ...
Decomposition of High Dimensional Aggregative Stochastic Control Problems
Abstract : We consider the framework of high dimensional stochastic control problem, in which the controls are aggregated in the cost function. As first contribution we introduce a modified problem, whose optimal control is under some reasonable assumptions an ε-optimal solution of the original problem. As second contribution, we present a decentralized algorithm whose convergence to the solution of the modified problem is established. Finally, we study the application to a problem of coordination of energy consumption and production of domestic appliances.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-02917014
Contributor : Adrien Seguret Connect in order to contact the contributor
Submitted on : Wednesday, October 20, 2021 - 5:27:04 PM
Last modification on : Sunday, June 26, 2022 - 3:16:46 AM
File
Decomposition of high dimensio...
Identifiers
  • HAL Id : hal-02917014, version 4
Citation
Adrien Seguret, Clémence Alasseur, J Frédéric Bonnans, Antonio de Paola, Nadia Oudjane, et al.. Decomposition of High Dimensional Aggregative Stochastic Control Problems. 2021. ⟨hal-02917014v4⟩
Share
Metrics
Record views
589
Files downloads
313
