IoTMap: A protocol-agnostic multi-layer system to detect application patterns in IoT networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
François Lesueur
Laurent Guyon
Hicham Ben-Hassine
  • Fonction : Auteur
The growth of the Internet of Things (IoT) results in a proliferation of different protocols (ZigBee, Bluetooth, 6LowPAN, Z-Wave, Wi-Fi, etc.). Organizations tend to quickly deploy several IoT applications over time and thus face heterogeneous IoT systems, combining different IoT protocols in different places of the overall system. This heterogeneity of protocols makes these networks hard to monitor or control, and some misconfigurations or unexpected device behaviours may even expose users to security issues. In this work, we propose the IoTMap system. IoTMap models interconnected and heterogeneous IoT networks, combining different protocols, by providing a generic stack and a unified packet format. IoTMap builds an iterative graph model where high-level semantics can progressively be deduced, ranging from packet transmission to application-type analysis. As such, IoTMap detects application behaviours amongst devices implementing different protocols, interconnected through a multi-protocol hub. In its current implementation (available at https://github.com/AlgoSecure/iotmap), IoTMap can inspect Zig- Bee, BLE and 6LowPAN networks.
iotmap.pdf (614.3 Ko) Télécharger le fichier
hal-02917680 , version 1 (19-08-2020)
  • HAL Id : hal-02917680 , version 1
Jonathan Tournier, François Lesueur, Frédéric Le Mouël, Laurent Guyon, Hicham Ben-Hassine. IoTMap: A protocol-agnostic multi-layer system to detect application patterns in IoT networks. 10th International Conference on the Internet of Things (IoT 2020), Oct 2020, Malmö, Sweden. ⟨hal-02917680⟩
123 Consultations
243 Téléchargements
