A Simple and Fast Algorithm for Computing the $N$-th Term of a Linearly Recurrent Sequence
We present a simple and fast algorithm for computing the $N$-th term of a given linearly recurrent sequence. Our new algorithm uses $O(\mathsf{M}(d) \log N)$ arithmetic operations, where $d$ is the order of the recurrence, and $\mathsf{M}(d)$ denotes the number of arithmetic operations for computing the product of two polynomials of degree $d$. The state-of-the-art algorithm, due to Charles Fiduccia (1985), has the same arithmetic complexity up to a constant factor. Our algorithm is simpler, faster and obtained by a totally different method. We also discuss several algorithmic applications, notably to polynomial modular exponentiation and powering of matrices.
