Universal lossless coding with random user access: The cost of interactivity, 2015 IEEE International Conference on Image Processing (ICIP), pp.1870-1874, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208128
Rate-storage regions for extractable source coding with side information, Physical Communication, vol.37, p.100845, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02390517
Compression de contenus 360 et transmission adaptéeà la navigation de l'utilisateur, Actes de la 27èmeédition du colloque Gretsi, 2019. ,
Incremental coding for extractable compression in the context of massive random access, IEEE Transactions on Signal and Information Processing over Networks, vol.6, pp.251-260, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02542972
Compound conditional source coding, slepian-wolf list decoding, and applications to media coding, 2007 IEEE International Symposium on Information Theory, pp.1511-1515, 2007. ,
On the duality between Slepian-Wolf coding and channel coding under mismatched decoding, IEEE Transactions on Information Theory, vol.55, issue.9, pp.4006-4018, 2009. ,
On information rates for mismatched decoders, IEEE Transactions on Information Theory, vol.40, issue.6, pp.1953-1967, 1994. ,
Mismatched decoding revisited: general alphabets, channels with memory, and the wide-band limit, IEEE Transactions on Information Theory, vol.46, issue.7, pp.2315-2328, 2000. ,
Mismatched decoding: Error exponents, second-order rates and saddlepoint approximations, IEEE Transactions on Information Theory, vol.60, issue.5, pp.2647-2666, 2014. ,
A geometryaware compression of 3d mesh texture with random access, 2019 Picture Coding Symposium (PCS), pp.1-5, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02380798
Mathematics of information and coding, Translations of mathematical monographs, vol.203, 2002. ,
Information Theory and Statistics: A Tutorial, Foundations and Trends in Communications and Information Theory, vol.1, issue.4, pp.417-528, 2004. ,
Modeling by shortest data description, Automatica, vol.14, issue.5, pp.465-471, 1978. ,
The Minimum Description Length Principle, 2007. ,
, Transmission and Storage Rates for Sequential Massive Random Access, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01799016
, Series in Telecommunications and Signal Processing, 2006.
Correlation model selection for interactive video communication, 2017 IEEE International Conference on Image Processing (ICIP), pp.2184-2188, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01590627
On the design of lowdensity parity-check codes within 0.0045 db of the shannon limit, IEEE Communications Letters, vol.5, issue.2, pp.58-60, 2001. ,
Design methods for irregular repeataccumulate codes, IEEE Transactions on Information Theory, vol.50, issue.8, pp.1711-1727, 2004. ,
Design of capacity-approaching irregular low-density parity-check codes, IEEE Transactions on Information Theory, vol.47, issue.2, pp.619-637, 2001. ,
Recent results in the shannon theory, IEEE Transactions on Information Theory, vol.20, issue.1, pp.2-10, 1974. ,
On the codebook-level duality between slepian-wolf coding and channel coding, 2007 Information Theory and Applications Workshop, pp.84-93, 2007. ,
Linear code duality between channel coding and slepian-wolf coding, 53rd Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.147-152, 2015. ,
Compression of binary sources with side information at the decoder using ldpc codes, IEEE Communications Letters, vol.6, issue.10, pp.440-442, 2002. ,
Analyzing symbol and bit plane-based ldpc in distributed video coding, 2007 IEEE International Conference on Image Processing, vol.2, 2007. ,
Low-density parity-check codes, IRE Transactions on Information Theory, vol.8, issue.1, pp.21-28, 1962. ,
Convergence behavior of iteratively decoded parallel concatenated codes, Modern coding theory, vol.49, pp.1727-1737, 2001. ,
, Channel Codes: Classical and Modern, 2009.
Information combining, Found. Trends Commun. Inf. Theory, vol.3, issue.3, pp.227-330, 2006. ,
Extrinsic information transfer functions: model and erasure channel properties, IEEE Transactions on Information Theory, vol.50, issue.11, pp.2657-2673, 2004. ,
Design of low-density parity-check codes for modulation and detection, IEEE Transactions on Communications, vol.52, issue.4, pp.670-678, 2004. ,
Ldpc code design for asynchronous slepian-wolf coding, IEEE Transactions on Communications, vol.58, issue.2, pp.511-520, 2010. ,
