Deriving concept hierarchies from text, Actes Annual International ACM SIGIR Conference on Research and Development in Information Retrieval, SIGIR'99, pp.206-213, 1999. ,
Semantic grounding of tag relatedness in social bookmarking systems, 7th International Semantic Web Conference, 2008. ,
Semantic Enrichment of Folksonomy Tagspaces, Actes International Semantic Web Conference, vol.5318, pp.889-894, 2008. ,
Integrating Folksonomies with the Semantic Web, Actes European Semantic Web Conference, vol.4519, pp.624-639, 2007. ,
What Can be Done with the Semantic Web? An Overview Watson-based Applications, CEUR Workshop Proceedings. CEUR-WS.org, vol.426, 2008. ,
Binary codes capable of correcting deletions, insertions and reversals, Soviet Physics Doklady, vol.10, issue.8, pp.707-710, 1966. ,
, Sémantique des folksonomies: structuration collaborative et assistée, Conférence IC 2009, pp.37-48, 2009.
Ontology of Folksonomy: A Mash-up of Apples and Oranges, International Journal on Semantic Web and Information Systems, vol.3, issue.2, pp.1-11, 2007. ,
, , 2005.
, Tagging Ontology -Towards a Common Ontology for Folksonomies, 2006.
, A New Modeling Method, Actes Semantic Authoring, Annotation and Knowledge Markup Workshop, vol.289, 2007.
Simple algorithms for representing tag frequencies in the scot exporter ,
, ACM International Conference on Intelligent Agent Technology, pp.536-539, 200770.
, Annotation Ontology Specification, 2007.
, Towards Semantically-Interlinked Online Communities. Actes European Semantic Web Conference, vol.3532, pp.500-514
, , 2005.
An Annotea Bookmark Schema, 2001. ,
, GRDDL Use Cases: Scenarios of extracting RDF data from XML documents. W3C Working Group Note, 2007.
Meaning Of A Tag: A collaborative approach to bridge the gap between tagging and Linked Data, Actes WWW2008 Workshop Linked Data on the Web, vol.369, 2008. ,
A URI is Worth a Thousand Tags: From Tagging to Linked Data with MOAT, International Journal on Semantic Web and Information Systems (IJSWIS), vol.5, issue.3, pp.71-94, 2009. ,
Speech acts meets tagging: NiceTag ontology, AIS SigPrag International Pragmatic Web Conference Track, I-Semantics, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00636128
NiceTag Ontology: tags as named graphs, International Workshop on Social Networks Interoperability at ASWC09 ,
URL : https://hal.archives-ouvertes.fr/hal-00437737
ontologie NiceTag : les tags en tant que graphes nommés, Atelier Web Social, 10ième Conférence Internationale Francophone sur l'Extraction et la Gestion des Connaissances, EGC, 2010. ,
Annotea: an open RDF infrastructure for shared Web annotations, International World Wide Web Conference (WWW10), pp.623-632, 2001. ,
com: A Reviewing and Rating Site for the Web of Data, International Semantic Web Conference and 2nd Asian Semantic Web Conference (ISWC/ASWC2007), vol.4825, pp.895-902, 2007. ,
Semantic tags, W3C SWEO Case Study, World Wide Web Consortium, 2008. ,
Dbpedia: A nucleus for a web of open data, International Semantic Web Conference and 2nd Asian Semantic Web Conference (ISWC/ASWC2007), vol.4825, pp.715-728, 2007. ,
Linked Data tagging with LODr, Semantic Web Challenge, 7th International Semantic Web Conference (ISWC), 2007. ,
Webmark: pour une approche contextuelle de la référence en ligne, Atelier Philosophie et Ingénierie, Le formel face à l'histoire, la technologie et la matérialité, IC2011, 2011. ,
Webmarks : Le marquage d'intérêt sur le Web de données, Proc. 12e Conférence Internationale Francophone sur l'Extraction et la Gestion de Connaissance, 2012. ,
Social bookmarking et tags structurés, IC2008, 19e Journées Francophones d'Ingénierie des Connaissances, 200890. ,
, Jena User Conference (JUC), 200692.
, GroupMe! -Where Semantic Web Meets Web 2.0, International Semantic Web Conference and 2nd Asian Semantic Web Conference (ISWC/ASWC2007), vol.4825, pp.871-878, 2007.
SweetWiki: A semantic wiki, Journal of Web Semantics, vol.6, issue.1, pp.84-97, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01154473
Reasoning in semantic wikis, Reasoning Web, vol.4636, pp.310-329, 2007. ,
Discovering Shared Conceptualizations in Folksonomies, Journal of Web Semantics, vol.6, issue.1, pp.38-53, 2008. ,
même application, d'autant plus que, comme nous l'avons montré, différents ponts existent entre ces artefacts cognitifs en théorie et en pratique. Ainsi, il est tout à fait possible de partir d'un aspect social et participatif (folksonomies) à partir duquel des structures plus formelles, offrant des capacités avancées de raisonnement, peuvent être extraites (thésaurus et ontologies) ou combinées. C'est de cette manière que nous pourrons parvenir à un Web à la fois Social et Sémantique, rejoignant les premières idées de Berners-Lee et des "machines sociales" 101 . Ainsi pour amener le web et ses ressources à leur plein potentiel, il est important de ne pas opposer les modèles existants de classification, d'organisation ou d'indexation et les pratiques émergeant 102 du web mais bien de rechercher activement leur complémentarité et leur interaction pour que ces artefacts s'enrichissent mutuellement dans des cycles de vie 103, Emer gent Semantics through the Tagging of Tags, International Workshop on Emergent Semantics and Ontology Evolution (ESOE2007), vol.292, 200799. ,
Weaving the Web: The Original Design and Ultimate Destiny of the World Wide Web by its Inventor, 1999. ,
, Vers des ontologies à l'état sauvage, Atelier IC 2.0, joint aux IC2008, 19èmes Journées Francophones d'Ingénierie des Connaissances, 2008.
A complete life-cycle for the semantic enrichment of folksonomies, Advances In Knowledge Discovery and Management, vol.3, p.133, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01171250
Un cycle de vie complet pour l'enrichissement sémantique des folksonomies, Proc. 11eme Conférence Internationale Francophone sur l'Extraction et la Gestion des Connaissances, 2011. ,
