Nonlinear Systems, ser. NJ 07458, 1996. ,
On characterizations of the input-to-state stability property, Systems & Control Letters, vol.24, issue.5, pp.351-359, 1995. ,
Input to state stability and allied system properties, Automation and Remote Control, vol.72, issue.8, pp.1579-1614, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00639491
Finite time stability of continuous autonomous systems, SIAM J. Control Optim, vol.38, issue.3, pp.751-766, 2000. ,
, Lyapunov Functions and Stability in Control Theory, 2005.
Smooth Lyapunov functions for homogeneous differential inclusions, Proceedings of the 41st SICE Annual Conference. SICE 2002, vol.3, pp.1974-1979, 2002. ,
Finite-time stabilization of stochastic high-order nonlinear systems with FT-SISS inverse dynamics, IEEE Transactions on Automatic Control, vol.64, issue.1, pp.313-320, 2018. ,
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Conditions for fixed-time stability and stabilization of continuous autonomous system, Systems & Control Letters, vol.129, pp.26-35, 2019. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
Applied nonlinear control, NJ, vol.199, issue.1, 1991. ,
Sliding mode control: theory and applications, 1998. ,
Terminal sliding mode control design for uncertain dynamic systems, Systems & Control Letters, vol.34, issue.5, pp.281-287, 1998. ,
Enhancing the settling time estimation of a class of fixed-time stable systems, International Journal of Robust and Nonlinear Control, vol.29, issue.12, pp.4135-4148, 2019. ,
A class of robust consensus algorithms with predefined-time convergence under switching topologies, International Journal of Robust and Nonlinear Control, vol.29, issue.17, pp.6179-6198, 2019. ,
A Lyapunov-like characterization of predefined-time stability, IEEE Transactions on Automatic Control, 2020. ,
Fast finite-time stability and its application in adaptive control of high-order nonlinear system, Automatica, vol.106, pp.339-348, 2019. ,
A new approach to fast global finite-time stabilization of high-order nonlinear system, Automatica, vol.81, pp.455-463, 2017. ,
A new second-order sliding mode and its application to nonlinear constrained systems, IEEE Transactions on Automatic Control, vol.64, issue.6, pp.2545-2552, 2018. ,
On fixed and finite time stability in sliding mode control, 52nd IEEE Conference on Decision and Control, pp.4260-4265, 2013. ,
Realization and discretization of asymptotically stable homogeneous systems, IEEE Transactions on Automatic Control, vol.62, issue.11, pp.5962-5969, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01514350
Consistent discretization of finite-time and fixed-time stable systems, SIAM Journal on Control and Optimization, vol.57, issue.1, pp.78-103, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01838712
Discretization of homogeneous systems using euler method with a state-dependent step, Automatica, vol.109, p.108546, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02164050
Finite-time input-to-state stability and applications to finite-time control design, SIAM Journal on Control and Optimization, vol.48, issue.7, pp.4395-4418, 2010. ,
Continuous finite-time stabilization of the translational and rotational double integrator, IEEE Trans. Automat. Control, vol.43, issue.5, pp.678-682, 1998. ,
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01098099
Stabilization of homogeneous systems using implicit control lyapunov functions, IFAC Proceedings Volumes, vol.40, pp.1120-1125, 2007. ,
On implicit finite-time and fixed-time ISS Lyapunov functions, 2018 IEEE Conference on Decision and Control (CDC), pp.706-710, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01888526
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.15, pp.273-283, 1966. ,
A smooth converse Lyapunov theorem for robust stability, SIAM J. Control Optim, vol.34, issue.1, pp.124-160, 1996. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
Finite-time and fixed-time observer design: Implicit Lyapunov function approach, Automatica, vol.87, pp.52-60, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01622356
Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942319
