Parametric recurrence quantification analysis of autoregressive processes for pattern recognition in multichannel electroencephalographic data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2021
Recurrence quantification analysis (RQA) is an acknowledged method for the characterization of experimental time series. We propose a parametric version of RQA, pRQA, allowing a fast processing of spatial arrays of time series, once each is modeled by an autoregressive stochastic process. This method relies on the analytical derivation of asymptotic expressions for five current RQA measures as a function of the model parameters. By avoiding the construction of the recurrence plot of the time series, pRQA is computationally efficient. As a proof of principle, we apply pRQA to pattern recognition in multichannel electroencephalographic (EEG) data from a patient with a brain tumor.
Ramdani-Pattern-Recognition-2020-postprint.pdf (2.4 Mo) Télécharger le fichier
hal-02921847 , version 1 (21-09-2020)
Sofiane Ramdani, Anthony Boyer, Stéphane Caron, François Bonnetblanc, Frederic Bouchara, et al.. Parametric recurrence quantification analysis of autoregressive processes for pattern recognition in multichannel electroencephalographic data. Pattern Recognition, 2021, 109, pp.#107572. ⟨10.1016/j.patcog.2020.107572⟩. ⟨hal-02921847⟩
283 Consultations
139 Téléchargements
