Theta-3 is connected, Computational Geometry: Theory and Applications, vol.47, issue.9, pp.910-917, 2014. ,
Connections between Theta-graphs, Delaunay triangulations, and orthogonal surfaces, Proceedings of the 36th International Conference on Graph Theoretic Concepts in Computer Science (WG 2010), pp.266-278, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00536710
Asymptotics of geometrical navigation on a random set of points in the plane, Advances in Applied Probability, vol.43, issue.4, pp.899-942, 2011. ,
On the spanning and routing ratio of Theta-four, Symposium on Discrete Algorithms, pp.2361-2370, 2019. ,
André van Renssen, and Sander Verdonschot. Towards tight bounds on theta-graphs: More is not always better, Journal of Computational Geometry jocg.org, vol.616, pp.70-93, 2016. ,
Optimal local routing on Delaunay triangulations defined by empty equilateral triangles, SIAM Journal on Computing, vol.44, issue.6, pp.1626-1649, 2015. ,
Online routing in triangulations, SIAM Journal on Computing, vol.33, issue.4, pp.937-951, 2004. ,
The ? 5 -graph is a spanner, Computational Geometry: Theory and Applications, vol.48, issue.2, pp.108-119, 2015. ,
On plane geometric spanners: A survey and open problems, Computational Geometry: Theory and Applications, vol.46, issue.7, pp.818-830, 2013. ,
There are planar graphs almost as good as the complete graph, Journal of Computer and System Sciences, vol.39, issue.2, pp.205-219, 1989. ,
A note on two problems in connexion with graphs, Numerische Mathematik, vol.1, pp.269-271, 1959. ,
Algorithm 447: Efficient algorithms for graph manipulation, Communications of the ACM, vol.16, issue.6, pp.372-378, 1973. ,
An improvement of the berry-esseen inequality with applications to poisson and mixed poisson random sums, Scandinavian Actuarial Journal, pp.1-25, 2010. ,
An algorithm for path connection and its applications, IRE Transaction on Electronic Computers, EC, vol.10, issue.3, pp.346-365, 1961. ,
The shortest path through a maze, Proceedings of the International Symposium on the Theory of Switching, pp.285-292, 1959. ,
Geometric Spanner Networks, 2007. ,
Approximating the d-dimensional complete Euclidean graph, Proceedings of the 3rd Canadian Conference on Computational Geometry (CCCG 1991), pp.207-210, 1991. ,
Stochastic and Integral Geometry. Probability and Its Applications, 2008. ,
