Measurement of Tongue Tip Velocity from Real-Time MRI and Phase-Contrast Cine-MRI in Consonant Production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Imaging Année : 2020
We evaluate velocity of the tongue tip with magnetic resonance imaging (MRI) using two independent approaches. The first one consists in acquisition with a real-time technique in the mid-sagittal plane. Tracking of the tongue tip manually and with a computer vision method allows its trajectory to be found and the velocity to be calculated as the derivative of the coordinate. We also propose to use another approach-phase contrast MRI-which enables velocities of the moving tissues to be measured directly. We recorded the sound simultaneously with the MR acquisition which enabled us to make conclusions regarding the relation between the movements and the sound. We acquired the data from two French-speaking subjects articulating /tata/. The results of both methods are in qualitative agreement and are consistent with other reviewer techniques used for evaluation of the tongue tip velocity.
jimaging-06-00031-v2.pdf (2.79 Mo) Télécharger le fichier
hal-02923466 , version 1 (27-08-2020)
Paternité
Karyna Isaieva, Yves Laprie, Freddy Odille, Ioannis K Douros, Jacques Felblinger, et al.. Measurement of Tongue Tip Velocity from Real-Time MRI and Phase-Contrast Cine-MRI in Consonant Production. Journal of Imaging, 2020, 6 (5), pp.31. ⟨10.3390/jimaging6050031⟩. ⟨hal-02923466⟩
137 Consultations
205 Téléchargements
