Conference papers
Sphere mapping for feature extraction from 360° fish-eye captures
Fatma Hawary 1 Thomas Maugey 1 Christine Guillemot 1
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Equirectangular projection is commonly used to map 360°captures into planar representation, so that existent processing methods can be directly applied to such content. Such format introduces stitching distortions that could impact the efficiency of further processing such as camera pose estimation , 3D point localization and depth estimation. Indeed, even if some algorithms, mainly feature descriptors, tend to remap the projected images into a sphere, important radial distortions remain existent in the processed data. In this paper , we propose to adapt the spherical model to the geometry of the 360°fish-eye camera, and avoid the stitching process. We consider the angular coordinates of feature points on the sphere for evaluation. We assess the precision of different operations such as camera rotation angle estimation and 3D point depth calculation on spherical camera images. Experimental results show that the proposed fish-eye adapted sphere mapping allows more stability in angle estimation, as well as in 3D point localization, compared to the one on projected and stitched contents. Index Terms-Spherical image, fish-eye camera, 360°, omnidirectional capture, feature extraction.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02924520
Contributor : Thomas Maugey Connect in order to contact the contributor
Submitted on : Friday, August 28, 2020 - 10:32:09 AM
Last modification on : Friday, April 8, 2022 - 4:04:02 PM
Long-term archiving on: : Sunday, November 29, 2020 - 12:19:49 PM
File
main.pdf
Identifiers
  • HAL Id : hal-02924520, version 1
Citation
Fatma Hawary, Thomas Maugey, Christine Guillemot. Sphere mapping for feature extraction from 360° fish-eye captures. MMSP 2020 - 22 nd IEEE International Workshop on Multimedia Signal Processing, Sep 2020, Tempere, Finland. pp.1-6. ⟨hal-02924520⟩
Share
Metrics
Record views
96
Files downloads
572
